This Toshiba Global AC Adapter is an external AC adapter designed to work with select Toshiba Satellite P100 notebook computers. Used as either a spare or replacement AC adapter, it has been tested and certified by Toshiba and meets or exceeds the specifications of the original AC adapter that came with your PC. This AC adapter powers your notebook computer via power outlet and lets you operate your computer as needed while recharging your notebook's battery. Stop weighing yourself down between office and home, get extra AC adapters to be kept at home, in the office or in your traveling bag.
- Toshiba Global AC Adapter - power adapter - 45 Watt
- Power adapter - external
- 170 g
- Localisation
- United States
- Input Voltage
- AC 120/230 V
- Output Voltage
- 19 V
- Power Capacity
- 45 Watt
- 9.14 cm x 4.06 cm x 2.54 cm
- 1-year warranty
- Designed For
- Dynabook Toshiba Portégé Z10, Z10T, Z15t, Z20T; Chromebook CB30, CB35; Chromebook 2; Satellite C55D, C70D, L30W, NB15t, P30W, U920T, U920T/00, U920T/023, U920t/Q001, U925T; Satellite Radius 12; Toshiba Satellite Click W35Dt; Toshiba WT310
- Localisation
- United States
- Input Voltage
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- Output Voltage
- 19 V
- Max Electric Current
- 2.37 A
- Power Capacity
- 45 Watt
- Cables Included
- Power cable 1.98 m
- Touch fastener
- RoHS
- Limited warranty - 1 year
- 9.14 cm
- 4.06 cm
- 2.54 cm
- 170 g
- Designed For
- Dynabook Toshiba Portégé Z10t-A, Z10t-A-001, Z10t-A-002-1, Z10t-A-003, Z10t-A-003-2, Z10t-A-005, Z10t-A-102, Z10t-A-103, Z10t-A-104, Z10t-A-106, Z10t-A-10H, Z10t-A-10M, Z10t-A-111, Z10t-A1110, Z10t-A1111, Z10T-A-112, Z10t-A-119, Z10t-A-11Q, Z10t-A-11Z, Z10t-A-121, Z10t-A-122, Z10t-A-12J, Z10t-A-12N, Z10t-A-12W, Z10t-A-12Z, Z10T-A-13R, Z10t-A-13T, Z10t-A-146, Z10t-A-14H, Z10t-A2111, Z15t-A1210, Z20t-B-10C, Z20t-B-10E, Z20t-B-10G, Z20t-B-10J, Z20t-B-10W, Z20t-B-10Z, Z20T-B-110, Z20t-B-111, Z20t-B-113, Z20t-B-115, Z20T-B-11E, Z20t-B-11P, Z20t-B-11Q , Toshiba Chromebook CB30-A3120, CB35-A3120 , Toshiba Chromebook 2 CB30-B3121, CB30-B3122 , Toshiba Satellite C55D-A-12K, C70D-A-108, C70D-A-10C, C70D-A-111, C70D-A-114, L30W-B-00L, NB15t-A1302, NB15t-A1303, P30W-B-00W, U920T/00S, U920T/023, U920t/Q001, U920t-00E, U920T-00X, U920T-01G, U920t-028, U920t-100, U920t-101, U920t-102, U920T-104, U920t-107, U920t-108, U920t-109, U920t-10F, U920t-10G, U920t-10H, U920t-10J, U920t-10K, U920t-10L, U920t-10M, U920t-10N, U920t-10P, U920t-10Q, U920t-10T, U920t-10V, U920t-10W, U920t-10Z, U920t-116, U920t-117, U920t-118, U920t-119, U920t-11C, U920t-11D, U920t-11E, U920t-11F, U920t-11G, U920t-11H, U920t-11J, U920t-11N, U925t-S2100, U925T-S2120, U925t-S2300, U925t-S2301 , Toshiba Satellite Radius 12 P20W-C-103, P20W-C-104, P20W-C-10H, P20W-C-10K , Toshiba Satellite Click W35Dt-A3300, W35Dt-AST2N01 , Toshiba WT310
