Your basket is empty
Toshiba Encore Power Adapter (WT8 / WT10)
Quicklinx: BXFWWS00 Mfr#: PA3996D-1AC3
Power adaptor for Toshiba Tablet PCs, AT200 & AT300:
  • Power out connection via USB connector
  • Dedicated for use in the UK, and countries using UK plugs.
  • 5V, 2A, 10W Out.
  • 3-pin input connector.
Toshiba AC Adaptor - power adapter
Power adapter
United Kingdom
Output Connector Type
USB
AC 100-240 V (50/60 Hz)
Voltage Provided
5 V
1 year warranty
AT300
Power adapter
Enclosure Colour
United Kingdom
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Power Provided
10 Watt
Max Electric Current
2 A
Limited warranty - 1 year
Toshiba AT300
