Product
Toshiba E300 2TB 3.5" 5700RPM 64MB Cache Low Energy Internal HDD
Quicklinx: BKT6WS00 Mfr#: HDWA120EZSTA
The quiet, low-energy eco model
Ideal for Reliability and Extended Use
2TB
5700rpm
64MB Buffer
Silent Design
Built-in silent operation technology introduces a new dimension of silent design.
Efficient Power Management
Energy consumption is reduced by 19 to 25% compared to 7,200-rpm models. Low temperature operation, curbing heat generation, raises reliability throughout the HDD service life.
Eco-Friendly Performance
Incorporating keen concern for the environment, there is full compliance with the ROHS directive defining Restriction of Hazardous Substances. For chlorine and bromine, monitoring holds concentrations within the voluntary standard values (900 ppm for each substance, combined ceiling of 1,500 ppm). The demand for alogen free operation is also addressed, yet another measure with ecology foremost in mind.
  • Everyday storage
    Ideal for the everyday user, Toshiba's E300 hard drive puts energy-efficient storage to work in your desktop PC. This low-energy hard drive makes it easy and secure to store anything from documents and data, to photos, movies, and music - so your media is ready to access at any time.
  • Performance alongside efficiency
    The E300's dual-stage actuator and RV sensor improve positional accuracy, negating the effects on head-track alignment that vibrations can cause. This design makes for more precise, faster read and write speeds for instant access to your data.
  • Low power consumption
    When compared to 7200 rpm hard drive models, the E300 cuts power consumption by up to 25%. The E300 is designed for users who want energy efficiency that doesn't compromise on storage space or read and write speeds - with a data buffer of 64 MB.
  • Low temperature, low noise
    Built-in silent operation technology ensures that the E300 operates quietly. Low RPM also reduces the generation of heat during operation - and with a low temperature, the E300 is designed to last longer throughout the HDD service life.
  • Advanced read and write technology
    With Perpendicular Magnetic Recording technology - which can deliver more than three times the storage density of traditional recording, and accounts for the E300's high capacity - and Tunnel Magneto-Resistive recording technology - for improved stability - the E300 is equipped for fast and secure reading and writing of data.
  • Keep data secure
    The E300's design includes an internal shock sensor, ensuring none of your data is lost. In addition, ramp loading technology means that when the hard drive or desktop PC are being transported, the drive slider does not make contact with the disk, making your data more secure.
Toshiba E300 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Spindle Speed
5700 rpm
RV Sensor, shock sensor, Native Command Queuing (NCQ), Halogen Free, Tunnel Magneto-resistive Recording (TMR) Head Technology, Ramp Load, Perpendicular Magnetic Recording (PMR), Advanced Format technology, Dual Stage Actuator (DSA)
101.6 mm x 147 mm x 26.1 mm
680 g
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
680 g
Performance
Average Latency
5.27 ms
Spindle Speed
5700 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
RoHS
