Toshiba Dynadock V3.0+ USB 3.0 Port Replicator
Quicklinx: 9J7ZWS00 Mfr#: PA5176E-1PRP
Toshiba's stylish dynadock V3.0+ universal docking station combines eye-catching looks with intelligent design to create a comprehensive workspace solution that's as compact as it is convenient. Plug in any laptop using a single cable and effortlessly connect to all your mobile and office peripherals, including your mouse, keyboard, external drives, HD TV, monitors, headphones, sound system, mobile phone and microphone. Four USB 3.0 ports offer speeds up to ten times faster than USB 2.0 and enable you to de-clutter your desk and get rid of messy cables without sacrificing functionality, or productivity. High-quality Gigabit LAN ensures quick, seamless networking, while Sleep-and-Charge technology is always on to keep your docked devices fully-powered and ready to go.
The dynadock V3.0+ also supports monitors with DVI, VGA or HDMI ports and video resolution of up to 2048 x 1152 pixels. It's the ideal way to stay organized.
Dynabook Dynadock V3.0+ - docking station - USB - DVI
Docking station
Docking Interface
USB
Video Interfaces
DVI
8.6 cm x 11 cm x 15.8 cm
290 g
United Kingdom, Europe
Power supply - external AC 120/230 V (50/60 Hz) 45 Watt Power Provided
Portégé X20W, Z30; Satellite C50, C50D, C50t, C55, C55D, C70, C70D, C75, C850, L50, L50D, L50t, M50, M50D, M50Dt, P70
Docking station
8.6 cm
11 cm
15.8 cm
290 g
Enclosure Colour
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x headset - output - mini-phone 3.5 mm
1 x DVI-VGA adapter , 1 x HDMI-DVI adapter , 1 x SuperSpeed USB cable
Power Provided
45 Watt
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Toshiba Portégé X20W-E-13J, Z30-E-12M , Toshiba Satellite C50-B-1C4, C50-B-1C5, C55-C-11F, C55-C-11J, C55-C-11K, C55-C-11P, C55-C-11R, C55-C-125, C55-C-12W, C55-C-12Z, C55-C-131, C55-C-134, C55-C-136, C55-C-137, C55-C-13X, C55-C-145, C55-C-14F, C55-C-16R, C55-C-170, C55-C-172, C55-C-173, C55-C-182, C55-C-186, C55-C-187, C55-C-189, C55-C-18G, C55-C-18J, C55-C-18T, C55-C-18W, C55-C-191, C55-C-19P, C55-C-1CK, C55-C-1DW, C55-C-1E2, C55-C-1E3, C55-C-1E4, C55-C-1E7, C55-C-1E9, C55-C-1EV, C55-C-1F0, C55-C-1F1, C55-C-1F7, C55-C-1FM, C55-C-1FN, C55-C-1G1, C55-C-1G6, C55-C-1G7, C55-C-1G8, C55-C-1GJ, C55-C-1GR, C55-C-1GT, C55-C-1GV, C55-C-1HX, C55-C-1J0, C55-C-1J6, C55-C-1J7, C55-C-1JE, C55-C-1JH, C55-C-1JL, C55-C-1JM, C55-C-1K1, C55-C-1K2, C55-C-1K3, C55-C-1KH, C55-C-1KJ, C55-C-1KM, C55-C-1KQ, C55-C-1KR, C55-C-1KT, C55-C-1KU, C55-C-1KW, C55-C-1KX, C55-C-1L0, C55-C-1L1, C55-C-1L3, C55-C-1L9, C55-C-1LJ, C55-C-1LK, C55-C-1LL, C55-C-1LP, C55-C-1LR, C55-C-1LT, C55-C-1LU, C55-C-1LV, C55-C-1M1, C55-C-1M8, C55-C-1M9, C55-C-1N8, C55-C-1NE, C55-C-1NZ, C55-C-1P3, C55-C-1P6, C55-C-1PN, C55-C-1PW, C55-C-1Q1, C55-C-1RT, C55-C-1RZ, C55-C-1T3, C55-C-1TD, C55-C-1TE, C55-C-1TF, C55-C-1TR, C55-C5208K, C55-C5212K, C70-C-18M, C70-C-18N, C70-C-197, C70-C-198, C70-C-199, C70-C-19C, C70D-C-12G, L50-C-111, L50-C-13C, L50-C-149, L50-C-154, L50-C-156, L50-C-157, L50-C-15H, L50-C-193, L50-C-1DW, L50-C-1GR, L50-C-1K4, L50-C-1KE, L50-C-1RP, L50-C-1RW, L50-C-1RX, L50-C-1RZ, L50-C-1T7, L50-C-1TD, L50-C-1UP, L50-C-1VJ, L50-C-1VU, L50-C-1VZ, L50-C-1WE, L50-C-1X2, L50-C-1XR, L50-C-1ZG, L50-C-214, L50-C-22D, L50-C-22E, L50-C-22H, L50-C-24Q, L50-C-25Q, L50-C-26L, L50-C-26M, L50-C-26N, L50-C-26P, L50-C-26Q, L50-C-26R, L50-C-26T, L50-C-26Z, L50-C-270, L50-C-275, L50-C-27N, L50-C-27P, L50-C-27Q, L50-C-27R, L50-C-27Z, L50-C-299, L50-C-29E, L50-C-29F, L50-C-29H, L50-C-29J, L50-C-29K, L50-C-29V, L50-C-29W, L50-C-2C3, L50-C-2C5, L50-C-2C6, L50-C-2C7, L50-C-2DG
