If your work demands cutting-edge detail, you'll find Toshiba's elegant dynadock 4K, with pristine Ultra HD or dual screen Full HD, the smartest way to streamline your life. With dynadock 4K you can simply plug in any notebook using a single cable - or effortlessly connect all your office and mobile needs, including your mouse, keyboard, external drives, HD TV, monitors, headphones, sound system, mobile phone and microphone. The stylish yet practical design means it can be placed vertically or horizontally, so you can keep your workspace neat and clutter-free. The dynadock 4K has six USB 3.0 ports, offering speeds up to ten times faster than USB 2.0 to ensure functionality won't be compromised - quite the opposite. Four ports are located on the back, while two are conveniently positioned on the front - complete with Sleep-and-Charge technology. That means your docked devices are fully charged and ready for action each morning. Premium Gigabit LAN ensures you have seamless network access across each device. As well as DisplayPort, the dynadock 4K also supports monitors with DVI-I or HDMI ports. That means that including the host PC monitor, the dynadock 4K enables you to use three high resolution displays at once - so you have ultimate flexibility in your media.
- Dynabook Dynadock 4K - docking station - USB - DVI, HDMI, DP - GigE
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- DVI, HDMI, DP
- 8.6 cm x 13 cm x 23.1 cm
- 317 g
- Black
- Localisation
- Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V (50/60 Hz)
- Designed For
- Toshiba Portégé A30, A30t, X20W, X30, X30T, Z20T, Z30, Z30t, Z40; Toshiba Satellite Pro A30, A40, A50, R40, R50; Toshiba Tecra A40, A50, X40, Z40, Z40T, Z50; Toshiba Portégé X20W, Z30; Satellite C70, L70, P50, P50t; Satellite Pro R50; Satellite Radius 14; 15; Tecra X40, Z50
- Product Type
- Docking station
- 8.6 cm
- 13 cm
- 23.1 cm
- 317 g
- Enclosure Colour
- Black
- Localisation
- Europe
- Data Link Protocol
- 6 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x microphone - line-In - mini-phone 3.5 mm , 1 x headphones - output - mini-phone 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x display / video - DisplayPort output - 20 pin DisplayPort
- Cables Included
- 1 x SuperSpeed USB cable
- Included Accessories
- Stand
- Security lock slot (cable lock sold separately), USB Sleep-and-charge ports
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Designed For
- Dynabook Toshiba Portégé A30-C-1MG, A30-C-1MX, A30-C-1PD, A30-C-1PE, A30-C-1PW, A30-C-1PX, A30-C-1QC, A30-C-1QD, A30-C-1RF, A30-C-1RU, A30-C-1RZ, A30-C-1T6, A30-D-134, A30-D-14V, A30-D-14W, A30-D-15Q, A30-D-18T, A30-D-19R, A30-D-1C9, A30t-C-156, A30t-C-157, X20W-D-145, X20W-E-10E, X20W-E-10N, X20W-E-11X, X20W-E-120, X20W-E-13P, X20W-E-13U, X20W-E-15V, X30-D-10N, X30-D-10P, X30-D-10R, X30-D-10T, X30-D-11M, X30-D-122, X30-D-137, X30-D-138, X30-D-13W, X30-D-13X, X30-D-14W, X30-D-15H, X30-D-15L, X30-D-16E, X30-D-16Q, X30-D-173, X30-D-17J, X30-D-17K, X30-D-17L, X30-D-187, X30-D-19C, X30-D-1D3, X30-D-1FX, X30-E-11T, X30-E-11U, X30-E-12F, X30-E-12N, X30-E-12W, X30-E-133, X30-E-139, X30-E-13C, X30-E-143, X30-E-14L, X30-E-14W, X30-E-162, X30-E-179, X30-E-17F, X30-E-18X, X30-E-1DD, X30T-E-108, X30T-E-109, X30T-E-10Q, X30T-E-10X, X30T-E-110, X30T-E-112, X30T-E-11R, X30T-E-13H, X30T-E-13M, X30T-E-13R, X30T-E-148, X30T-E-14G, X30T-E-153, X30T-E-1D8, X30T-E-1DP, X30T-E-1E1, Z30-E-10X, Z30-E-114, Z30-E-12L, Z30-E-13M, Z30-E-15X, Z30-E-15Z , Dynabook Toshiba Satellite Pro A30-C-1JG, A30-D-11E, A30-D-125, A40-D-11F, A40-D-13W, A40-D-151, A50-D-150, A50-D-16W, A50-D-18V, A50-D-18W, A50-D-1J0, A50-D-1L2, A50-E-148, A50-E-14E, A50-E-16J, A50-E-16T, A50-E-1G4, A50-E-1HT, A50-E-1MZ, A50-EC-11J, A50-EC-11K, R40-C-14N, R50-C-17Z, R50-D-13K, R50-E-10V, R50-E-127, R50-E-129, R50-E-12E, R50-E-12G, R50-E-12P, R50-E-15Z, R50-E-17M, R50-E-18D, R50-E-18F, R50-E-18G , Dynabook Toshiba Tecra A40-D-12Z, A40-D-19U, A40-D-1EL, A40-D-1F2, A50-D-1E2, A50-D-1M4, A50-D-1PM, A50-D-1PR, A50-E-110, A50-E-13J, A50-E-13K, A50-E-13U, A50-E-19H, A50-E-1DJ, A50-E-1LJ, X40-D-10L, X40-D-1DT, X40-E-10Q, X40-E-10W, X40-E-10X, X40-E-115, X40-E-11M, X40-E-123, X40-E-12P, Z50-D-11Q, Z50-E-10J, Z50-E-10R, Z50-E-116, Z50-E-11F, Z50-E-14E, Z50-E-14F , Toshiba Portégé X20W-E-13J, Z30-E-12M , Toshiba Satellite Pro R50-E-12Q , Toshiba Tecra X40-E-114, Z50-E-10T, Z50-E-10Z
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
