Expand your computer's potential with the dynadock U3.0, the universal docking station that links all your electronic devices to your laptop with just one single USB 3.0 cable. With one simple cable connection to your computer, you can access to large screen displays, stereo speakers, external hard drive, optical drive, printer, full-size keyboard and mouse. Surf the Internet while you listen to music, check your email and social networking accounts, watch streaming videos, write a paper, work on a presentation, or whatever else you can imagine!
The dynadock U3.0 has a built-in HD digital video card supporting dual display output. Connect one or two external displays with resolution up to 2048 x 1152 each. View up to 3 displays simultaneously. 3.5 mm audio ports or the HDMI out port can also pump out 5.1 surround sound, providing a true multimedia experience.
Dynabook Dynadock U3.0 Universal USB 3.0 Docking Station - docking station - USB - DVI, HDMI - 1GbE
Docking station
Docking Interface
USB
Video Interfaces
DVI, HDMI
11.4 cm x 13 cm x 23.3 cm
530 g
Glossy black
Audio Output
Sound card - 5.1 channel surround
Gigabit Ethernet
Power adapter AC 100/240 V (50/60 Hz)
Toshiba Portégé A30, A30t, X20W, X30, X30T, Z20T, Z30, Z30t, Z40; Toshiba Satellite Pro A30, A50, C30, R50; Toshiba Tecra A40, A50, X40, Z40, Z40T, Z50; Portégé X20W, Z30; Satellite Pro R50; Tecra X40, Z50
Docking station
11.4 cm
13 cm
23.3 cm
530 g
Enclosure Colour
Glossy black
Audio
Audio Output
Sound card
Sound Output Mode
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x microphone - line-In - mini-phone 3.5 mm , 1 x headphones / speakers - line-out - mini-phone stereo 3.5 mm , 3 x speakers - line-out - mini-phone stereo 3.5 mm , 2 x USB 2.0 - 4 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B
1 x SuperSpeed USB cable , 1 x DVI-VGA adapter
Security lock slot (cable lock sold separately), USB Sleep-and-charge ports
Power adapter
Microsoft Windows 7 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Dynabook Toshiba Portégé A30-C-1MG, A30-C-1MX, A30-C-1PE, A30-C-1PW, A30-C-1PX, A30-C-1QC, A30-C-1QD, A30-C-1RF, A30-C-1RU, A30-C-1RZ, A30-C-1T6, A30-C-1TZ, A30-D-14V, A30-D-14W, A30-D-15Q, A30-D-163, A30-D-18T, A30-D-19R, A30-D-1C9, A30t-C-156, A30t-C-157, X20W-D-145, X20W-E-10J, X20W-E-10N, X20W-E-11F, X20W-E-11X, X20W-E-120, X20W-E-13P, X20W-E-13U, X20W-E-15V, X30-D-10N, X30-D-10P, X30-D-10R, X30-D-10T, X30-D-11M, X30-D-122, X30-D-137, X30-D-138, X30-D-13W, X30-D-13X, X30-D-14W, X30-D-15H, X30-D-15L, X30-D-16E, X30-D-16Q, X30-D-173, X30-D-17J, X30-D-17K, X30-D-17L, X30-D-187, X30-D-19C, X30-D-1D3, X30-D-1FX, X30-E-11T, X30-E-11U, X30-E-12F, X30-E-12N, X30-E-12W, X30-E-133, X30-E-136, X30-E-137, X30-E-139, X30-E-13D, X30-E-13E, X30-E-143, X30-E-14L, X30-E-14W, X30-E-162, X30-E-179, X30-E-17F, X30-E-18X, X30-E-1DD, X30T-E-108, X30T-E-109, X30T-E-10C, X30T-E-10Q, X30T-E-10X, X30T-E-110, X30T-E-112, X30T-E-11R, X30T-E-13H, X30T-E-13M, X30T-E-13R, X30T-E-148, X30T-E-14G, X30T-E-153, X30T-E-1D8, X30T-E-1DP, X30T-E-1E1, Z30-E-10P, Z30-E-10X, Z30-E-114, Z30-E-12L, Z30-E-13M, Z30-E-15X, Z30-E-15Z , Dynabook Toshiba Satellite Pro A30-C-1JG, A30-D-11E, A30-D-125, A50-D-150, A50-D-16W, A50-D-1J0, A50-E-16J, A50-E-1G4, A50-E-1HT, A50-E-1MZ, A50-EC-11J, A50-EC-11K, C30-K-10Q, C30-K-110, R50-D-13K, R50-E-10V, R50-E-129, R50-E-12P, R50-E-17M, R50-E-18D, R50-E-18F, R50-E-18G , Dynabook Toshiba Tecra A40-D-12Z, A40-D-19U, A40-D-1EL, A40-D-1F2, A40-K-15G, A50-D-14X, A50-D-1E2, A50-D-1J4, A50-D-1J5, A50-D-1KW, A50-D-1M4, A50-D-1PM, A50-D-1PR, A50-E-110, A50-E-13J, A50-E-13K, A50-E-19H, A50-E-1DJ, A50-E-1LJ, A50-K-16E, X40-D-10L, X40-D-1DT, X40-E-10N, X40-E-10Q, X40-E-10W, X40-E-10X, X40-E-115, X40-E-11M, X40-E-11Q, X40-E-123, X40-E-12P, Z50-E-10J, Z50-E-10W, Z50-E-116, Z50-E-11F, Z50-E-14E, Z50-E-14F , Toshiba Portégé X20W-E-13J, Z30-E-12M , Toshiba Satellite Pro R50-E-12Q , Toshiba Tecra X40-E-114, Z50-E-10T, Z50-E-10Z, Z50-E-11K
