The Tecra A40-D's optimized dual antenna design ensures you've always got the excellent connection - so nothing gets in the way of you accessing, saving and sharing your work.
Designed for productivity
With a full-size, silent-type keyboard, you can write documents comfortably without disturbing coworkers or family - whether you're at the desk, or at home. -
The instant office
The Tecra A40-D has a range of full-size ports built in, making it a fully-functional standalone PC in any setting. And when combined with the High Speed Port Replicator III docker, it instantly transforms your desk into a multi-featured office workstation. That means you can take advantage of two digital video outs, as well as four additional USB 3.0, and two more USB 2.0 ports, amongst others. This combination makes the Tecra A40-D the perfect replacement for a desktop, while its easy-to-carry chassis makes it your ideal laptop too.
- Dynabook Toshiba Tecra A40-D-1HL - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Input Device
- ClickPad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell - up to 7.5 hours
- 3-axis accelerometer
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Steel grey metallic, matte black (keyboard)
- 34.01 cm x 24.41 cm x 2.38 cm
- 1.95 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Bundled Services
- 1 Year Reliability Guarantee
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2 SATA
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Resolution
- 0.9 Megapixel
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, touchpad, ClickPad
- Multi-gesture touch pad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 7.5 hours
AC Adapter
- Input
- AC 100/240 V
- Output
- 19 V, 2.37 A
Connections & Expansion
- 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack , USB 3.0 (Sleep & Charge) , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Case Material
- Magnesium alloy
- Integrated Options
- Dockable
- Security
- Administrator password, system password, hard drive password, remote boot control
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.95 kg
- ENERGY STAR Certified
- Bundled Services
