Toshiba Dynabook Satellite Pro A50 Core i7-8550U 8GB 1TB 15.6" Windows 10 Professional 64-bit
Quicklinx: FGX2WS00 Mfr#: PT5A1E-02U00CEN
Display Size: 15.6in
Processor Model: I7-8550U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
  • Core i7
  • IEEE 802.11n
£639.37 ex VAT
£767.24 inc VAT
No matter what your business needs, the Satellite Pro A50-EC has the right combination of a processor, drive and screen resolution for enhanced productivity.
  • Productivity your way
    No matter what your business needs, the Satellite Pro A50-EC has the right combination of processors, drives and screen resolutions for enhanced productivity. Choose up to an 8th Generation Intel Core processor and tailor the performance to your requirements to create a business laptop that's perfect for you.
  • Business-enhancing features
    The Satellite Pro A50-EC was developed with business in mind. Intel Wi-Fi and LAN offer seamless connectivity, while the 39.6 cm (15.6") non-reflective HD or Full HD screen ensures you can review content with crystal-clear clarity.
  • Keeping data secure
    The Satellite Pro A50-EC has been drop and spill-tested* to help safeguard your data. With a Kensington lock slot to offer security for the devices itself and TPM to encrypt your data to ensure it doesn't fall into the wrong hands, the A50-EC will keep your data safe and secure. You can even choose an optional fingerprint reader that makes the Satellite Pro A50-EC easy to access in the right hands, and almost impenetrable in the wrong ones. *Drop-tested up to 70cm. Spill-resistant keyboards help protect your data from accidental spills up to 30 ml, allowing you 3 minutes shut down time to save your data.
  • Connected to your business needs
    With a built-in USB Type-C slot that offers Display Port and Power Delivery, single cable docking is straightforward, helping you save, store and share data easily. Plus thanks to HDMI, RGB, USB 3.0 and LAN ports, connecting directly to peripherals is also simple.
  • Personalise your profession
    The Satellite Pro A50-EC supports a wide range of accessories designed for business users. Simply plug your device, display and accessories into the USB-C dock and enjoy immediate connectivity between them all, with minimum cable clutter.The USB-C Dock charges and connects to all your peripherals with only one cable. Extend hard drive space with Dynabook's external devices, and transport the device safely with official bags, sleeves and trolleys. *Accessories sold separately. Please check the range of accessories available at.
  • Certified eco-friendly
    Take control of your environmental impact with Dynabook's EPEAT Gold certified Satellite Pro A50-EC with Eco Utility built-in. With easy to customise settings you can quickly maximise your power efficiency, minimise your energy consumption and reduce the impact your work has on the planet.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Satellite Pro A50-EC-142 - 15.6" - Core i7 8550U - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
8 GB DDR4
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell - up to 8.67 hours
3-axis accelerometer
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Graphite black
37.9 cm x 25.8 cm x 2.405 cm
2 kg
Region: United Kingdom, Ireland
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, Full HD eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.9 Megapixel
Video Resolutions
1280 x 720
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, ClickPad
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8.67 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
2 x USB 3.1 , VGA , HDMI , Headphone/microphone combo jack , LAN , USB 3.1 (Sleep & Charge) , USB-C/DisplayPort (Power Delivery)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Microsoft Office 365 (30 days trial), DTS Sound
Graphite black
Integrated Options
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2 kg
ENERGY STAR Certified
Software applications
Toshiba Dynabook Satellite Pro A50 Core i7-8550U 8GB 1TB 15.6 Bundle deal on Toshiba Dynabook Satellite Pro A50 Core i7-8550U 8GB 1TB 15.6" Windows 10 Professional 64-bit
£738.54
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: Intel UHD Graphics 620
Hard Drive Type: HDD
Brand: Toshiba
Price Range Ex VAT: 500 - 750
