Make your day simpler with the reliable Satellite Pro A50-EC. Its multiple configurations have been built to suit you and improve productivity.
Productivity your way
No matter what your business needs, the Satellite Pro A50-EC has the right combination of processors, drives and screen resolutions for enhanced productivity. Choose up to an 8th Generation Intel Core processor and tailor the performance to your requirements to create a business laptop that's perfect for you. -
Business-enhancing features
The Satellite Pro A50-EC was developed with business in mind. Intel Wi-Fi and LAN offer seamless connectivity, while the 39.6 cm (15.6") non-reflective HD or Full HD screen ensures you can review content with crystal-clear clarity. -
Keeping data secure
The Satellite Pro A50-EC has been drop and spill-tested* to help safeguard your data. With a Kensington lock slot to offer security for the devices itself and TPM to encrypt your data to ensure it doesn't fall into the wrong hands, the A50-EC will keep your data safe and secure. You can even choose an optional fingerprint reader that makes the Satellite Pro A50-EC easy to access in the right hands, and almost impenetrable in the wrong ones. *Drop-tested up to 70cm. Spill-resistant keyboards help protect your data from accidental spills up to 30 ml, allowing you 3 minutes shut down time to save your data. -
Connected to your business needs
With a built-in USB Type-C slot that offers Display Port and Power Delivery, single cable docking is straightforward, helping you save, store and share data easily. Plus thanks to HDMI, RGB, USB 3.0 and LAN ports, connecting directly to peripherals is also simple. -
Personalise your profession
The Satellite Pro A50-EC supports a wide range of accessories designed for business users. Simply plug your device, display and accessories into the USB-C dock and enjoy immediate connectivity between them all, with minimum cable clutter.The USB-C Dock charges and connects to all your peripherals with only one cable. Extend hard drive space with Dynabook's external devices, and transport the device safely with official bags, sleeves and trolleys. *Accessories sold separately. Please check the range of accessories available at. -
Certified eco-friendly
Take control of your environmental impact with Dynabook's EPEAT Gold certified Satellite Pro A50-EC with Eco Utility built-in. With easy to customise settings you can quickly maximise your power efficiency, minimise your energy consumption and reduce the impact your work has on the planet. -
Services for a flawless performance
The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
- Dynabook Toshiba Satellite Pro A50-EC-11J - 15.6" - Core i5 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell - up to 8.66 hours
- 3-axis accelerometer
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Graphite black, black (keyboard)
- 37.9 cm x 25.8 cm x 2.405 cm
- 2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - pick-up and return - 1 year - carry-in
- Bundled Services
- 1 Year Reliability Guarantee
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2 SATA
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-glare, Full HD eDP
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Video Resolutions
- 1920 x 1080
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, ClickPad
- Numeric Keypad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 8.66 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- 2 x USB 3.1 , VGA , HDMI , Headphone/microphone combo jack , LAN , USB 3.1 (Sleep & Charge) , USB-C (supports DisplayPort Alt Mode) (Power Delivery)
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Microsoft 365 (30 days trial), DTS Sound
- Integrated Options
- Security
- Administrator password, system password, hard drive password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 2 kg
- ENERGY STAR Certified
- Bundled Services
