Toshiba Dynabook Portege X30 Core i5-8250U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FGV5WS00 Mfr#: PT282E-0VC00TEN
Display Size: 13.3in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£980.67 ex VAT
£1,176.80 inc VAT
The Portégé X30-E is just 15.9 mm thin but it can power through your workload with its powerful processor. And it doesn't overheat, thanks to the Hybrid Air Cooling technology - so everything runs fast and smoothly, even in a sleek and light chassis.
  • Made with pride
    The Portégé X30-E is just 15.9 mm thin and 1.05 kg in weight but it can power through your workload with your choice of up to an 8th generation Intel Core processor. And it doesn't overheat, thanks to our new Hybrid Air Cooling technology – so everything runs fast, and runs smoothly, even in a sleek and light chassis.
  • Security, assured
    Built on our own unique in-house BIOS, we've added two-factor authentication - including IR-based Windows Hello and built-in fingerprint reader - to the security features of the Portégé X30-E. It's the device you can trust with an optional Toshiba Slim cable lock for physical security.
  • For however you work
    We build everything with you in mind. The Portégé X30-E is equipped with a non-reflective touchscreen and brand new In-Cell Touch technology, which enables you to navigate and interact with content without compromising on the slim design of the device or the clarity of the display. Connect on the go with optional mobile broadband including LTE.
  • Productivity unleashed
    We have packed the Portégé X30-E with the latest high performance technology. In this honeycomb-structured magnesium design you will find your choice of up to an 8th generation Intel Core processor and twin USB Type-C Thunderbolt 3 enabled ports for extendable connectivity. A blistering fast PCIe SSD drive with up to 1TB of space completes the picture.
  • Content that fills a room
    The Portégé X30-E is equipped with Harman/Kardon speakers with DTS that give you crisp sound, clear music and video audio that really fills a meeting room. The HDMI port means you can share on-screen content on a larger display or TV.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Portégé X30-E-1J2 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache /
8 GB DDR4
Storage
256 GB SSD
Optical Drive
No optical drive
Display
13.3" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
AccuPoint, SecurePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell - up to 14.45 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Matte black (keyboard), onyx blue with hairline
31.6 cm x 22.7 cm x 1.64 cm
1.05 kg
Region: United Kingdom, Ireland
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Slots Qty
2
Storage
Main Storage
256 GB SSD - (M.2) PCIe
Display
13.3"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
IR camera, Windows Hello
Sound
Harman/kardon stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, AccuPoint, SecurePad
Keyboard Backlight
Glass finished Securepad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Wi-Fi CERTIFIED
3-cell Lithium Ion
Run Time
Up to 14.45 hours
AC Adapter
Input
AC 120/230 V
Output
20 V, 2.25 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 (Sleep & Charge) , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery/data/video) , HDMI
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office 365 (30 days trial)
Security
Intel Authenticate
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
Localization
1.05 kg
ENERGY STAR Certified
Software applications
Toshiba Dynabook Portege X30 Core i5-8250U 8GB 256GB SSD 13.3 Bundle deal on Toshiba Dynabook Portege X30 Core i5-8250U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
£1,079.84
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Toshiba
Price Range Ex VAT: 750 - 1000
