Toshiba Dynabook Portege X20W Core i7-8550U 16GB 512GB SSD 12.5" Windows 10 Professional 64-bit
Quicklinx: FGV0WS00 Mfr#: PRT22E-0CP00SEN
Display Size: 12.5in
Processor Model: I7-8550U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
£1,587.56 ex VAT
£1,905.07 inc VAT
Portégé X20W-E is packed full of powerful technology in a professional 2-in-1. With a full-power processor and Toshiba's Hybrid Air Cooling System to keep things running smoothly, this 2-in-1 with a fully magnesium chassis represents the height of engineering excellence.
Featuring a SecurePad with a fingerprint reader, Portégé X20W-E is equipped for professional-standard security to protect your business-critical data. With Toshiba's own built-in BIOS and TPM 2.0 encryption, it's robust and ready to work securely anywhere.
Portégé X20W-E is built for daily working with a long battery life and step charge technology that delivers four additional hours from a 30-minute charge. With a non-reflective Corning Gorilla Glass 4 screen and Thunderbolt 3 connectivity, there's nothing holding you back from being productive - wherever you are.
  • Elegant design that packs an unexpected punch
    The Portégé X20W-E is packed full of powerful technology in a professional 2-in-1, at only 15.4 mm and 1.1 kg. With full power 7th generation Intel Core processors and Toshiba's Hybrid Air Cooling System to keep things running smoothly this 2-in-1 with a fully magnesium chassis represents the height of engineering excellence.
  • Unshakeable mobile security
    Featuring a SecurePad with fingerprint reader and optional IR-camera for face authentication through Windows Hello or Intel Authenticate, the Portégé X20W-E is equipped for professional-standard security to protect your business-critical data. With Toshiba's own built-in BIOS and TPM 2.0 encryption, it's robust and ready to work securely anywhere.
  • An all-day business partner
    The Portégé X20W-E is built for daily working, with a 13.5 hour battery life* and step charge technology that delivers four additional hours from a 30 minute charge. With a non-reflective Corning Gorilla Glass 4 screen and Thunderbolt 3 connectivity, plus configurable mobile broadband including LTE, there's nothing holding you back from being productive - wherever you are. *Measured with Mobile Mark 2014. Mobile Mark is a trademark of Business Applications Performance Corporation.
  • Capture your ideas without compromise
    With an AES stylus pen, palm rejection technology, and a keyboard that's not only backlit but also pitched perfectly for added comfort, the Portégé X20W-E is designed for enhanced usability – so you can capture your ideas with ease.
  • Extended productivity
    Alongside the Portégé X20W-E, the Thunderbolt 3 Dock and the USB-C Travel Dock both have a full range of ports including USB type C, USB 3.0, HDMI, DisplayPort, VGA and LAN. They also both power the notebook, cutting down on cable clutter.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Portégé X20W-E-13U - 12.5" - Core i7 8550U - 16 GB RAM - 512 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
16 GB LPDDR3
Storage
512 GB SSD
Optical Drive
No optical drive
Display
12.5" touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Stylus, SecurePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Wireless Broadband (WWAN)
4G LTE
3-cell - up to 11.83 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Tile matte black (keyboard), onyx blue with hairline
29.9 cm x 21.9 cm x 1.54 cm
1.1 kg
Region: United Kingdom, Ireland
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - pick-up and return - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Operating System
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
16 GB
Max RAM Supported
16 GB
LPDDR3 SDRAM
Speed
2133 MHz
Storage
Main Storage
512 GB SSD - (M.2) PCIe
Display
12.5"
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Anti-reflective, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, stylus, SecurePad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Wi-Fi CERTIFIED
Generation
4G
GSM, GPRS, EDGE, HSPA+, LTE
Controller
Sierra Wireless EM7455
3-cell lithium polymer
Run Time
Up to 11.83 hours
AC Adapter
Input
AC 120/230 V
Output
20 V, 2.25 A
Connections & Expansion
USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery/data/video) , USB 3.0 (Sleep & Charge) , Headphone/microphone combo jack , HDMI (on supplied adapter)
Software
Software Included
Microsoft Office 365 (30 days trial)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter, USB-C to HDMI adapter, AES Stylus Pen
Localization
1.1 kg
ENERGY STAR Certified
Software applications
Toshiba Dynabook Portege X20W Core i7-8550U 16GB 512GB SSD 12.5 Bundle deal on Toshiba Dynabook Portege X20W Core i7-8550U 16GB 512GB SSD 12.5" Windows 10 Professional 64-bit
£1,686.73
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Toshiba
Price Range Ex VAT: 1500+
