Store data securely on the new Canvio Slim external hard drives. Its elegant slim and lightweight design makes it a perfect travel companion. Transfer your files via SuperSpeed USB 3.0 and keep them safe using a password lock. The pre-loaded NTI® Backup Now EZ™ software allows easy automated backups. You can also use the Canvio Slim on PC and Mac thanks to Tuxera HTFS for Mac driver (included).
Perfect travel companion
With a super slim design that looks good and is light enough to carry anywhere, you will want to store and share your data securely wherever you go.
Auto-backup software and NFTS driver for Mac included
Pre-loaded NTI® Backup Now EZ™ software automates file, folder, and full system backup and recovery for complete peace of mind. And you can use the Canvio Slim on both Windows PC and Apple Macintosh platforms, thanks to the onboard Tuxera NTFS for Mac driver.
SuperSpeed USB 3.0 for faster transfers
Powered by new USB 3.0 technology, the Canvio Slim is far faster than—but still compatible with—USB 2.0 technology. That's important for speedy transfer when organising your files.
Safely locked away
Lock your Canvio Slim with a password that's unique to you - and prevent unauthorised users from accessing important data stored on your hard drive.
- Toshiba StorE Slim - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication
- Power Source
- USB bus
- Enclosure Colour
- Black
- Bundled with
- 10GB free Cloud Backup
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Bundled with
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Software Included
- NTI Backup NOW! EZ, Tuxera HTFS
- Enclosure Colour
- Black
