Toshiba Canvio For Desktop 4TB 3.5" - Black
Quicklinx: CNDVWS00 Mfr#: HDWC340EK3JA
Store the largest of digital libraries and access it quickly using the Canvio for Desktop, with up to 6 TB storage and super-fast USB 3.0 transfer speeds. Its compact piano black design makes it a smart desktop addition, positioned horizontally or vertically. An internal shock sensor and ramp loading technology keeps your drive safe, and you can use the pre-loaded software to backup and restore files, folders or your entire system.
Fast transfer speeds
Canvio for Desktop hard drives use USB 3.0 technology to transfer data over ten times faster than USB 2.0 (which is still supported). Combine this with up to 6 TB of storage, and you can manage the largest of files with ease.
Auto-backup software
Pre-loaded NTI® Backup Now EZ™ software automates file, folder, and full system backup and recovery for complete peace of mind.
Extra security
Protect your private data and secure the drive using the security lock slot.
PC and Mac compatible
Canvio for Desktop hard drives come with a NTFS driver for Mac, allowing you to store and access files on both PC and Mac without reformatting.*
* Reformatting to HFS+ required for use with Apple® Time Machine® software.
Eco power-off
The eco power off function helps you use less electricity without affecting the performance of the hard drive.
Toshiba Canvio for Desktop - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
3.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Security lock slot (cable lock sold separately), shock sensor, Ramp Load, NTFS formatted
Power Source
Included AC adapter
Enclosure Colour
129.5 mm x 41.5 mm x 167 mm
903 g
United Kingdom, Europe
4 TB
3.5"
USB 3.0
129.5 mm
41.5 mm
167 mm
903 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
Software Included
NTI Backup NOW! EZ, Tuxera NTFS Driver for Mac, Toshiba Password Lock
Microsoft Windows 7, Windows 8.1, Windows 10, Apple MacOS X 10.8 - 10.11
1 x USB 3.0 cable - external
Enclosure Colour
