Toshiba Battery Li-Ion 6 Cell 5100mAh
Quicklinx: 8NBFWS00 Mfr#: PA3788U-1BRS
The Toshiba Primary Battery Pack is a rechargeable, Lithium Ion battery. Used as either a spare or replacement battery, this battery pack meets or exceeds the specifications of the original battery that came with your notebook. It interfaces with the Toshiba Power Saver Utility on the notebook which features a charge indicator to help you monitor the available power.
Toshiba Primary Battery Pack - laptop battery - Li-Ion - 5100 mAh
Laptop battery
327 g
Lithium Ion 6-cell - 5100 mAh
Batteries Qty
1
Run Time (Up To)
4.6 hours
20.6 cm x 4.5 cm x 2 cm
1-year warranty
Dynabook Toshiba Satellite Pro S500; Toshiba Tecra A11, A11 3G-13, M11, S11
Laptop battery
Quantity
1
6-cell Lithium Ion
Voltage Provided
10.8 V
5100 mAh
Run Time (Up To)
4.6 hrs
Limited warranty - 1 year
20.6 cm
4.5 cm
2 cm
327 g
Dynabook Toshiba Satellite Pro S500-0EE, S500-0HS, S500-12M, S500-12Z, S500-133, S500-138, S500-139, S500-13L, S500-140, S500-141, S500-144, S500-147, S500-14L, S500-14M, S500-14Z, S500-150, S500-155, S500-156, S500-158, S500-159, S500-15C, S500-15E, S500-15K, S500-15W , Dynabook Toshiba Tecra A11-07G, A11-07H, A11-07J, A11-103, A11-105, A11-10M, A11-11D, A11-11K, A11-123, A11-12D, A11-14P, A11-15D, A11-15P, A11-16L, A11-16M, A11-16W, A11-17N, A11-17T, A11-182, A11-183, A11-186, A11-187, A11-188, A11-18C, A11-18M, A11-19C, A11-19E, A11-19K, A11-19L, A11-19M, A11-19N, A11-19P, A11-19V, A11-1C1, A11-1CF, A11-1CP, A11-1CV, A11-1D1, A11-1D2, A11-1D4, A11-1D7, A11-1D9, A11-1DC, A11-1DT, A11-1E5, A11-1E6, A11-1E7, A11-1EE, A11-1EG, A11-1EH, A11-1EJ, A11-1ET, A11-1EU, A11-1EV, A11-1EW, A11-1F4, A11-1FM, A11-1FP, A11-1FR, A11-1FW, A11-1FX, A11-1FZ, A11-1G1, A11-1G6, A11-1G7, A11-1G8, A11-1G9, A11-1GE, A11-1GJ, A11-1HE, A11-1HK, A11-1HL, A11-1HP, A11-1HX, A11-1HZ, A11-1J2, A11-1J7, A11-1J9, A11-1JL, A11-1JQ, A11-1Jw, A11-1JZ, A11-EV1, A11-S3512, A11-S3522, A11-S3532, A11-S3541, A11-SP5003L, A11-SP5003M, A11-SP5010L, A11-SP5010M, A11-SP5011L, A11-SP5011M, A11-ST3500, A11-ST3501, A11-ST3503, A11-ST3504, A11-W3540, A11-W3541, M11-035, M11-036, M11-037, M11-047, M11-049, M11-04K, M11-05T, M11-12T, M11-12U, M11-130, M11-135, M11-137, M11-13X, M11-14C, M11-14D, M11-14L, M11-15U, M11-15W, M11-15X, M11-15Z, M11-162, M11-16C, M11-16R, M11-174, M11-177, M11-17E, M11-17M, M11-17T, M11-17U, M11-17V, M11-17W, M11-17Z, M11-180, M11-18D, M11-192, M11-19C, M11-19D, M11-S3412, M11-S3422, M11-SP4002L, M11-SP4002M, M11-ST3503, M11-ST3504, M11-ST3510, M11-W3421, M11-W3422, S11-0CN, S11-0CP, S11-0CQ, S11-0CR, S11-0CS, S11-0LW, S11-104, S11-10E, S11-10F, S11-126, S11-13X, S11-14M, S11-14N, S11-14P, S11-14R, S11-14T, S11-14U, S11-154, S11-15G, S11-15H, S11-15L, S11-15M, S11-15N, S11-160, S11-166, S11-167, S11-168, S11-16G, S11-16P, S11-172, S11-173
