Toshiba B-EX4T1 300dpi Direct Thermal Transfer Printer
Quicklinx: BW79WS00 Mfr#: B-EX4T1-TS12-QM-R
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Technology: Direct thermal
Max Paper Size: Roll (12 cm)
Hurry, only 3 left in stock!
£951.09 ex VAT
£1,141.30 inc VAT
The B-EX series combines the tried and trusted features and functionality of the B-SX range with enhancements to increase performance and operability. Reliability and performance usually come at a cost, but with the B-EX series, premium capabilities come as standard, essentially lowering initial capital outlay and future-proofing your investment.
  • Usability
    Continuing on from the easy operation of the SX range, the B-EX range also incorporates a user-replaceable snap-in printhead and platen roller, further reducing maintenance costs. The unique intuitive graphical LCD 'helpdesk' display improves usability and prompts even the novice user to take immediate corrective action where necessary, keeping user training to a minimum.
  • Durability
    Toshiba has packed the superior design elements of the market-leading B-SX4 into the matt-black B-EX4 to provide customers with a high-end industrial product at a mid-range price. Features include: side opening; double ribbon motor control; automatic center media loading; near-edge or flat printhead; optional ribbon save; BCI (Basic Command Interpreter) compatibility. (Toshiba uses Basic Command Language to control the printer's interface.)
  • Fast and flexible
    With a speed of 14 ips, the B-EX4 boasts a 40 % improvement in productivity on the SX range (10 ips). Ethernet and USB 2.0 are standard with options for parallel, serial and wireless LAN. It is fully compatible with the B-SX range, allowing for the swift migration of legacy printers. In addition, advanced processing capabilities facilitate high throughput.
  • Enhanced functionality
    The B-EX range boasts further sophisticated features: data logging function; internal file storage; automatic thermal printhead DPI detection; LAN address display; simple LAN set-up; graphical sensor threshold on display; auto-home position function; firmware update via external memory; RFID ready.
  • Emulation functionality
    The emulation functionality enables Toshiba printers to work with ZPL II data streams allowing you to enhance your labels without modifying your current system. No software changes are required, just install the printer and start working. Free yourself from the restrictions of your legacy systems, protect your future investments and lower the total cost of ownership (also available for other datastreams).
  • Low TCO
    Toshiba technology has enabled a dramatic reduction in operating costs, further lowering an already legendary low 'total cost of ownership' (TCO). B-EX is equipped with the world-class green technology ribbon saving function (optional), with a nearly 70% overall lower power consumption on stand-by power compared to its predecessor. Ribbon wrinkle canceling also reduces paper and ribbon wastage. These special features reduce operating costs whilst assisting environmental conservation.
  • Toshiba designs
    Combining 'Voice of the Customer' with state-of-the-art research and design allows Toshiba to produce superior, robust and reliable solutions that provide the functionality and operability needed for today's demanding industrial environments.
Toshiba TEC B-EX4T1-TS12-QM-R - label printer - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer
Max Media Size
Roll (12 cm)
Max Media Size (Custom)
120 mm
Print Speed
Up to 355 mm/sec
Max Resolution (B&W)
305 dpi
USB, LAN
Language Simulation
ZPL II
Barcodes
GS1 DataBar
Media Type
Labels, continuous forms
Fonts
Outline
Network adapter - Ethernet - integrated
Printer Features
RFID ready
9 months warranty
27.8 cm x 46 cm x 31 cm
Printer Type
Printer
Print Speed
Up to 355 mm/sec - 305 dpi
Built-in Devices
Status LCD
Wired
USB, LAN
305 dpi
Language Simulation
ZPL II
Fonts
Outline
Fonts Included
1 x outline
Barcodes
GS1 DataBar
Printer Features
RFID ready
Media Handling
Media Type
Max Media Size
Roll (12 cm)
120 mm
Max Printing Width
104 mm
Roll Maximum Outer Diameter
200 mm
Roll Core Diameter
25 mm
Media Feeders
1 x manual - 1 roll - Roll (12 cm)
Network adapter - integrated
Ethernet
Remote Management Protocol
SNMP
1 x LAN - RJ-45 , 1 x USB 2.0
RoHS
Environmental Standards
ENERGY STAR
Limited warranty - 9 months , Limited warranty - 4 months - on-site , Limited warranty - printhead - 6 months
27.8 cm
46 cm
31 cm
Type: Printer
Brand: Toshiba
Price Range Ex VAT: 750 - 1000
