This Toshiba Global AC Adapter is an external AC adapter designed to work with select Toshiba Satellite P100 notebook computers. Used as either a spare or replacement AC adapter, it has been tested and certified by Toshiba and meets or exceeds the specifications of the original AC adapter that came with your PC. This AC adapter powers your notebook computer via power outlet and lets you operate your computer as needed while recharging your notebook's battery. Stop weighing yourself down between office and home, get extra AC adapters to be kept at home, in the office or in your traveling bag.
- Toshiba Global AC Adapter - power adapter - 45 Watt
- Power adapter - external
- 206 g
- Input Voltage
- AC 100-240 V
- Output Voltage
- 19 V
- Power Capacity
- 45 Watt
- 4.6 cm x 9.4 cm x 2.5 cm
- 1-year warranty
- Designed For
- Dynabook Toshiba Portégé R30, Z30, Z930; Toshiba Satellite Pro C50, C70, L70, L850, NB10, R50, T130/00; Satellite C50, C55, C660/00, C660/01, C660/02, C70, C75, C850, C855, C870, C875, L50, L55, L70, M50, NB10, P50, P845, S50, S70, T130, T130/01, T130/03, U50, U840, U845, U940/K002, W30, Z30, Z930
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Output Voltage
- 19 V
- Max Electric Current
- 2.37 A
- Power Capacity
- 45 Watt
- Cables Included
- No power cord is included
- Cable management
- RoHS
- Limited warranty - 1 year
- 4.6 cm
- 9.4 cm
- 2.5 cm
- 206 g
- Designed For
- Dynabook Toshiba Portégé R30-A-10H, R30-A-10R, R30-A-138, Z30-A-108 (45 Watt), Z30-A-115, Z30-A-11G (45 Watt), Z30-A-12P (45 Watt), Z30-A-136 (45 Watt), Z30-A-138 (45 Watt), Z30-A-13E, Z30-A-13R, Z30-A-13U, Z30-A-13W (45 Watt), Z30-A-14K, Z30-A-159, Z30-A-1FL, Z930-08E (45 Watt) , Dynabook Toshiba Satellite Pro C50-A-1FM (45 Watt), C70-A-14X (45 Watt), NB10-A-105 (45 Watt), NB10-A-109 (45 Watt), R50-B-10H, R50-B-10K, R50-B-10L, R50-B-10R, R50-B-11C , Toshiba Satellite C50-A-108 (45 Watt), C50-A-10D (45 Watt), C50-A-12C (45 Watt), C50-A-14W (45 Watt), C50-A-1G4 (45 Watt), C50-A-1KQ, C50-B-10P, C50-B-12L, C50-B-12M, C50-B-13K, C50D-A-10Z, C50D-A-130 (45 Watt), C50D-A-147, C50D-B-10V, C50D-B-10X, C55-A-12W (45 Watt), C55-A-1F5 (45 Watt), C55-A-1GT (45 Watt), C55-A-1N2 (45 Watt), C55-A-1N4 (45 Watt), C55-A-1N5 (45 Watt), C55-A-1N8 (45 Watt), C55-A-1N9 (45 Watt), C55-A-1ND (45 Watt), C55-A-1NE (45 Watt), C55-A-1P2 (45 Watt), C55-A-1P7 (45 Watt), C55-A-1Q5 (45 Watt), C55-A-1QH (45 Watt), C55-A5388 (45 Watt), C55-A5390 (45 Watt), C70-A-14Z (45 Watt), C70-A-150 (45 Watt), C70-A-157 (45 Watt), C70-A-15D, C70-A-15G (45 Watt), C70-A-15U, C70-A-160 (45 Watt), C70-A-16N, C70D-A-10L, C70D-A-11C, C75-A-12D (45 Watt), C75-A-13M (45 Watt), C75-A-13T (45 Watt), C75-A-15E, C75-A7390 (45 Watt), C75D-A-10C, C850-1MJ (45 Watt), C855-244 (45 Watt), L50-A-1CW (45 Watt), L50-A-1EC, L50-A-1EH (45 Watt), L50-B-11Z, L50-B-120, L50-B-124, L50-B-13D, L50-B-13M, L50-B-159, L50-B-177, L50-B-17C, L50-B-181, L50-B-182, L50-B-18K, L50-B-196, L50-B-19M, L50-B-1C9, L50-B-1CC, L50-B-1D5, L50-B-1D6, L50-B-1DK, L50-B-1DP, L50-B-1DQ, L50-B-1DR, L50-B-1DW, L50-B-1DX, L50-B-1E2, L50-B-1E3, L50-B-1E4, L50-B-1GC, L50D-B-11Q, L50D-B-11V, L50D-B-11W, L50t-B-11R, L50t-B-11V, L70-A-10G (45 Watt), L70-A-13P (45 Watt), M50-A-108 (45 Watt), P50-A-113 (45 Watt), P50-A-137 (45 Watt), P50-A-13C (45 Watt), P50-A-13Q (45 Watt), P50-A-144, Z30-A-177, Z30t-A-10C
