Toshiba’s N300 3.5-inch internal hard disk offers unprecedented reliability for NAS and other high-performance storage systems. It is optimized to meet the reliability, endurance, performance and scalability requirements of 24-hour x 7-day high-capacity storage for personal, home office and small business use. The N300 is available in capacities of up to 6 TB.
Use for:
• Up to 8-bay NAS
• Desktop RAID and servers
• Multimedia server storage
Optimised for use in 1-8 bay NAS enclosures
3.5" SATA hard drive
7200 rpm / 128 MB buffer
Reliable always-on operation
NAS systems in small businesses or creative environments often need to be accessed by several users, at different locations, simultaneously. Therefore NAS drives must deliver high data transfer rates and simultaneous upload and download 24 hours a day, 7 days a week. Offering high reliability and scalability, N300 drives achieve an incredible performance. -
High durability and heat prevention
Use of high-endurance components is one of the reasons that the N300 series offers better durability than other conventional hard disk drives. At the same time, automatic adjustment of seek speed to reduce heat during high-temperature operation further improves endurance in demanding situations. -
High speed for multi-drive environment
High performance and fast read speed is made possible under high data access loads from multiple users. This makes the drive suitable for small businesses and creative professionals looking for solutions to handle high data volumes using multi-RAID NAS environments.
- Toshiba N300 NAS - hard drive - 6 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 6 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Shock sensor, NAS compatible, 24x7 continuous operation, vibration sensor, workload up to 180 TB per year
- 101.85 mm x 147 mm x 26.1 mm
- 770 g
- 3-year warranty
- Capacity
- 6 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- 101.85 mm
- 147 mm
- 26.1 mm
- 770 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 241 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- RoHS
- Package Type
- Bulk
- Limited warranty - 3 years
- 0 °C
- 65 °C
