Toshiba batteries are of the same quality, reliability, and specification as the original primary pack included with your Notebook. Whether replacing an old battery, or simply wishing to carry a spare, the Toshiba range will enable you to be more productive and provide you with the power you need, when you need it.
- Toshiba Battery Pack - laptop battery - Li-Ion - 4400 mAh
- Laptop battery
- 320.7 g
- Battery
- Lithium Ion 6-cell - 4400 mAh
- Black
- 20.45 cm x 5.18 cm x 2.02 cm
- 1-year warranty
- Designed For
- Satellite C50, C850, C850/04, C850D, C855, C855D, C870, C870D, C875, C875D, L830, L840, L850, L850/05, L850D, L850D/001, L855, L855D, L870, L870D, L875, L875D, P845, P845t, P850, P855, P870, P875
- Laptop battery
- Black
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 4400 mAh
- Limited warranty - 1 year
- 20.45 cm
- 5.18 cm
- 2.02 cm
- 320.7 g
- Designed For
- Toshiba Satellite C50-A-15L, C850-059, C850-1DZ, C850-1G6, C850-1GP, C850-1GQ, C850-1K7, C850-1K9, C850-1KG, C850-1KW, C850-1M9, C850-1MH, C850-1MJ, C850-1MN, C850-1MZ, C850-1NM, C850-1NN, C850-1P6, C850-1PM, C850D-10J, C850D-12Q, C850D-137, C850D-13G, C855-1KN, C855-1LP, C855-1QK, C855-1T4, C855-1UD, C855-1UT, C855-1Z6, C855-21U, C855-22N, C855-23Z, C855-241, C855-244, C855-245, C855-24C, C855-25T, C855-285, C855-28J, C855-2FG, C855-2FU, C855-2G2, C855-2GQ, C855-2HC, C855-2HT, C855-2HU, C855-2HV, C855-2HW, C855-2J2, C855-2J3, C855-2J4, C855-2J7, C855-2JK, C855-2KR, C855-2L9, C855-2LC, C855-2LJ, C855-2M1, C855-2M3, C855D-10W, C855D-12K, C855D-13T, C855D-14X, C855D-154, C855D-15V, C855D-162, C855D-16J, C855D-170, C855D-S5203, C855D-S5238, C855D-SP5162KM, C855D-SP5265FM, C855-S5107, C855-S5132NR, C855-S5236, C855-S5355, C855-S5630, C855-SP5266KM, C870-17Q, C870-17W, C870-1DJ, C870-1E8, C870-1FD, C870-1FF, C870-1H1, C870-1HN, C870-1HP, C870-1HR, C870-1J1, C870-1J4, C870-1JE, C870-1JL, C870-1JR, C870-1K1, C870D-122, C870D-12F, C870D-12M, C875-13H, C875-14Z, C875-S7132NR, L830-14J, L830-14M, L830-16E, L830-16G, L830-16M, L830-16W, L850-1F0, L850-1MK, L850-1NP, L850-1T0, L850-1T5, L850-1T7, L850-1UT, L850-1UW, L850-1V2, L850-1V6, L850-1VF, L850-1VV, L850-1W5, L850-1WU, L850-1WZ, L850-1XE, L850-1XK, L850-1XW, L850-1Z2, L850D-13F, L855-14J, L855-15J, L855-162, L855-166, L855-16H, L855-171, L855-175, L855-176, L855-17Z, L855-180, L855D-10L, L855D-S5139NR, L855D-SP5169KM, L855D-SP5266KM, L855-S5121, L855-S5138NR, L855-S5157, L855-S5162, L855-S5163, L855-S5187, L855-S5372, L855-S5375, L870-17K, L870-192, L870-193, L870-196, L870-198, L870-19M, L870-19N, L875-13C, L875-13D, L875D-10R, L875D-S7131NR, P845-S4200, P845t-110, P845t-112, P845t-SP4101L, P850-335, P850-337, P855-33Q, P855-34L, P855-SP5163SM, P855-SP5302SL, P870-31K, P870-32P, P870-332, P870-333, P870-334, P870-335, P870-338, P875-32K, P875-32L, P875-32Q, P875-32R
