Move Beyond HDD
If your PC can‘t keep up with you, it‘s time to upgrade with a Toshiba Q300 Solid State Drive. With 3-bit-per-cell flash and unique Toshiba controller technology, you‘ll experience high-speed boot up and fast system responsiveness. A Q300 SSD is a fantastic upgrade that will increase your performance both in the office and out.
Performance For Everyday Use
Upgrade to a fast, efficient Toshiba Q300 Solid State Drive with capacities up to 960 GB thanks to 3-bit-per-cell flash technology. A solid state drive reduces OS boot time and speeds up your computing system responsiveness rates by leaps and bounds. That's so you can enjoy more of what you want to browse and to create.
Give Yourself A Boost!
The SSD Q300 uses 3-bit-per-cell flash to maximise storage capacity, without sacrificing speed. Thanks to advanced-speed and Adaptive Size SLC Write Cache technology your system will be more responsive than ever. From the first boot, you’ll experience speedier web browsing, emailing, media playback, lite gaming and more.
One Step Ahead
Zeroing Trim Support keeps write speeds high by emptying unneeded stored data in advance. When new data needs to be stored, all is clear for swift operations.
Lining Things Up For More Speed
Native Comman Queuing (NCQ) realigns commands on the fly to optimise SSD access. This further accelerates the speed of data read/write performance.
Quality You Can Trust
Toshiba is the inventor of flash memory, and has a well-earned worldwide reputation for producing high-quality technology. Toshiba SSDs are based on NAND Flash technology and incorporate Toshiba controllers to achieve industry-leading levels of performance and reliability. Not only that, we are so confident of the longevity, we back it up with a 3 year warranty.
Performance for everyday use
A solid state drive reduces OS boot time and speeds up your computing system responsiveness rates by leaps and bounds. -
Give yourself a boost
The SSD Q300 uses 3-bitper- cell flash to maximize storage capacity, without sacrificing speed. Your system will be more responsive than ever. -
Lining things up for speed
- Toshiba Q300 - SSD - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- NAND Flash Memory Type
- 15nm single-level cell (SLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Native Command Queuing (NCQ), shock resistant, vibration dampening, Garbage Collection technology, Zero Trim Support, Adaptive Size SLC Write cache technology, Toshiba TC58NC1000 controller, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 3-year warranty
- Capacity
- 480 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
Performance
- SSD Endurance
- 120 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- Maximum 4KB Random Write
- 83000 IOPS
- Maximum 4KB Random Read
- 86000 IOPS
Reliability
- MTBF
- 1,500,000 hour(s)
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3.6 Watt (active) , 0.3 Watt (idle)
- Software Included
- NTI Echo (free download), Toshiba Storage Utility Tool (free download)
- Included Accessories
- Mounting spacer
- JESD-219A
- Limited warranty - 3 years
- 0 °C
- 65 °C
