Toshiba 3TB SATA 6Gb/s 7200RPM 64MB 3.5" Hard Drive
Quicklinx: 8TZLWS00 Mfr#: DT01ACA300
1 on order, delivery delayed
Toshiba's 7200 RPM 3.5-inch HDD series is optimized for use in power-friendly consumer and commercial desktop computers, gaming PCs and external HDDs. The DT01ACA300 offers up to 3 TB capacity and uses advanced format and leverages a best-in-class power management technology. In addition, this desktop drive provides up to 16% idle power savings over the previous model. The 6 Gb/s SATA interface drives deliver 7200 RPM performance. These HDDs are designed to allow manufacturers to leverage the benefits of the latest components and operating systems to deliver high-performance, high-capacity, power-efficient systems.
2 Year Warranty
Toshiba DT01ACA300 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal - Halogen Free, Advanced Format technology
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Halogen Free, Advanced Format technology, S.M.A.R.T.
10.16 cm x 14.7 cm x 2.61 cm
680 g
Microsoft Certification
Compatible with Windows 7
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
10.16 cm
14.7 cm
2.61 cm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.4 Watt (active) , 1 Watt (idle)
RoHS
60 °C
Shock Tolerance
70 g @ 2ms half-sine pulse (operating) / 300 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.67 g @ 5-500 Hz (operating) / 1.04 g @ 2-200 Hz (non-operating)
Sound Emission
27 dB
