Toshiba 3TB Canvio Premium USB 3.0 2.5" Portable Drive Grey
Quicklinx: DC91WS00 Mfr#: HDTW230EB3CA
  • High-class storage for all your files
    Up to 3 TB housed in a stylish aluminum design with diamond-cut edges, make this drive the ultimate companion for any device, no matter if on your desk or on the move.
  • Extra connectivity
    Two supported USB types for the connectivity of the future. With the small, included Type-A to Type-C USB adapter, the Canvio Premium offers everything you need for data transfers to and from different devices. So no matter if your notebook or desktop PC comes with a USB Type-A or a USB Type-C connection, the Canvio Premium has got you covered.
  • Protect your data
    Stop unauthorized users from accessing your private information with the included Toshiba Storage Security Software, allowing you to secure your hard drive with a unique password.
  • Automatic backup solution
    The included Toshiba Storage Backup Software comes with an intuitive and user-friendly interface, making the backup of your data a breeze. Simply choose your individual files or folders, intervals and time settings for your backups, and let the software take care of the rest.
  • High transfer speeds
    Powered by USB 3.0 technology, these portable hard drives are much faster than - but still compatible with - USB 2.0 devices, allowing for speedy transfer when organizing your files.
Toshiba Canvio Premium - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, Bus Powered by USB, NTFS formatted
Power Source
USB bus
Enclosure Colour
Dark grey metallic, diamond cut design
78 mm x 109 mm x 19 mm
225 g
3-year warranty
3 TB
USB 3.0
78 mm
109 mm
19 mm
225 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Software Included
Toshiba Backup Software, Toshiba Password Protection
Microsoft Windows 7 / 8.1 / 10
Carrying pouch
1 x USB 3.0 cable - USB Type A to micro-B - external , 1 x USB adapter - USB-C to Type A - external
Enclosure Colour
Shipping Width
128 mm
Shipping Depth
140 mm
Shipping Height
40 mm
Shipping Weight
335 g
Limited warranty - 3 years
