Your basket is empty
Toshiba 3TB Canvio Connect II USB 3.0 2.5" Portable Hard Drive Blue
Quicklinx: B79GWS00 Mfr#: HDTC830EL3CA
Form Factor: 2.5"
Capacity: 3TB
Interface: USB 3.0
3 on order, no confirmed delivery date
£84.98 ex VAT
£101.97 inc VAT
Access your files anywhere and from any device. The Canvio Connect II is a smart storage solution that fits in the palm of your hand.
Toshiba Canvio Connect II - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB, NTFS formatted
Power Source
USB bus
Enclosure Colour
Blue
7.8 cm x 10.9 cm x 1.95 cm
230 g
Bundled with
10GB free Cloud Backup
3 TB
2.5"
USB 3.0
7.8 cm
10.9 cm
1.95 cm
230 g
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
2.5"
Power Source
USB bus
Software Included
NTI Backup NOW! EZ, Pogoplug PC, Tuxera NTFS Driver for Mac
Apple MacOS X 10.6.6 or later, Microsoft Windows 7 / 8 / 8.1
System Requirements Details
750 MHz - RAM 256 MB
1 x USB 3.0 cable - USB Type A to micro-B - external
Enclosure Colour
Blue
Form Factor: 2.5"
Capacity: 3TB
Interface: USB 3.0
Brand: Toshiba
Price Range Ex VAT: 50 - 100
