Your basket is empty
Toshiba 32GB Exceria N302 SD Card
Quicklinx: CBFRWS00 Mfr#: THN-N302R0320E4
Put the Toshiba N302 memory card in your digital camera or your mobile device and expand your storage. You can take many pictures with your smartphone or store songs and videos.
Toshiba EXCERIA N302 - flash memory card - 32 GB - SDHC UHS-I
Flash memory card
SDHC UHS-I Memory Card
Storage Capacity
32 GB
Speed Rating
UHS-I U3 / Class10
5 years warranty
Flash memory card
Storage Capacity
32 GB
Compatibility
Non-specific
SD Speed Class
UHS-I U3 / Class10
Read Rate
Up to 90 MB/s
Limited warranty - 5 years
24 mm
32 mm
2.1 mm
2 g
