Toshiba 2TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black)
Quicklinx: 8L57WS00 Mfr#: HDWC120EK3J1
Store data securely on the new STOR.E CANVIO external hard drives. It's quick and easy to transfer your files via SuperSpeed USB 3.0, and you can also organise data and backup files with pre-loaded NTI® Backup Now EZ™ software. Backward compatible with USB 2.0, the STOR.E CANVIO features versatile mounting options and is available in two colour variations.
Smart. Safe. Speedy
The STOR.E CANVIO Desktop is the smart, speedy way to preserve your favourite files and memories. USB 3.0 makes it super-fast, and it`s backwards compatible so connecting to USB 2.0 devices is no problem. The pre-loaded NTI® Backup Now EZ™ software is a complete back-up solution to keep your files safe. And password encryption goes the extra mile to guard against intruders.
  • Super Speed Storage USB 3.0
  • Backup Software onboard
  • Password encryption
  • Warranty - 2 year(s)
  • Portable peace of mind
    With Toshiba's Canvio 3.0 portable hard drive you get a complete backup solution without the worries. It is home sweet home for all your documents, music, pictures or videos and a great way to share.
  • Extra hard drive protection
    Offering a built-in internal shock sensor and ramp-loading technology, Canvio 3.0 portable hard drives help safeguard your data against accidents, drops and other unfortunate real-life scenarios.
  • A stylish design
    Canvio 3.0 portable hard drive is easy to carry, stay where you put them, and make quite a fashion statement.
  • Faster transfer speeds
    Featuring USB 3.0 technology, Canvio 3.0 portable hard drive is far faster than - but still compatible with - USB 2.0 technology.
  • Cloud backup capabilities
    Put your backups on the cloud and your concerns on hold. The Canvio 3.0 portable hard drive comes with integrated cloud backup capabilities.
Toshiba StorE Canvio - hard drive - 2 TB - USB 3.0
Hard drive - external (desktop)
2 TB
3.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, NTFS formatted
Power Source
Included AC adapter
Enclosure Colour
4.2 cm x 12.9 cm x 16.7 cm
United Kingdom, Europe
Microsoft Certification
Compatible with Windows 7
2 TB
3.5"
USB 3.0
4.2 cm
12.9 cm
16.7 cm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
3.5"
Power Source
Included AC adapter
Power adapter
AC 120/230 V
Software Included
NTI Backup NOW! EZ
Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - 750 MHz - RAM 256 MB (USB 2.0)
1 x USB 3.0 cable - USB Type A to micro-B - external
Enclosure Colour
