High-class storage for all your files
Up to 3 TB housed in a stylish aluminum design with diamond-cut edges, make this drive the ultimate companion for any device, no matter if on your desk or on the move. -
Extra connectivity
Two supported USB types for the connectivity of the future. With the small, included Type-A to Type-C USB adapter, the Canvio Premium offers everything you need for data transfers to and from different devices. So no matter if your notebook or desktop PC comes with a USB Type-A or a USB Type-C connection, the Canvio Premium has got you covered. -
Protect your data
Stop unauthorized users from accessing your private information with the included Toshiba Storage Security Software, allowing you to secure your hard drive with a unique password. -
Automatic backup solution
The included Toshiba Storage Backup Software comes with an intuitive and user-friendly interface, making the backup of your data a breeze. Simply choose your individual files or folders, intervals and time settings for your backups, and let the software take care of the rest. -
High transfer speeds
Powered by USB 3.0 technology, these portable hard drives are much faster than - but still compatible with - USB 2.0 devices, allowing for speedy transfer when organizing your files.
- Toshiba Canvio Premium - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable) - password authentication, Bus Powered by USB, NTFS formatted
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication, Bus Powered by USB, NTFS formatted
- Power Source
- USB bus
- Enclosure Colour
- Dark grey metallic, diamond cut design
- 78 mm x 109 mm x 13.5 mm
- 160 g
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 78 mm
- 109 mm
- 13.5 mm
- 160 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Software Included
- Toshiba Backup Software, Toshiba Password Protection
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Included Accessories
- Carrying pouch
- Cables Included
- 1 x USB 3.0 cable - USB Type A to micro-B - external , 1 x USB adapter - USB-C to Type A - external
- Enclosure Colour
- Shipping Width
- 128 mm
- Shipping Depth
- 140 mm
- Shipping Height
- 40 mm
- Shipping Weight
- 273 g
- Limited warranty - 3 years
