The Canvio Premium for Mac has a high quality diamond-cut aluminum design that will complement your high-end Mac devices.
- Toshiba Canvio Premium for Mac - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication, Bus Powered by USB, Apple Time Machine compatible, HFS+ formatted
- Power Source
- USB bus
- Enclosure Colour
- Silver metallic
- 78 mm x 13.5 mm x 109 mm
- 165 g
- Capacity
- 1 TB
- Interface
- USB 3.0
- 78 mm
- 13.5 mm
- 109 mm
- 165 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Software Included
- Pogoplug (10 GB Cloud Storage)
- OS Required
- Apple MacOS X 10.8 - 10.11
- Included Accessories
- Carrying pouch
- Cables Included
- 1 x USB 3.0 cable - USB Type A to micro-B - external , 1 x USB adapter - USB-C to Type A - external
- Enclosure Colour
- Silver metallic
