Toshiba 1TB Canvio Basics 2018 USB 3.0 2.5" Portable Hard Drive
Quicklinx: DC8FWS00 Mfr#: HDTB410EK3AA
Form Factor: 2.5"
Capacity: 1TB
Interface: USB 3.0
Stock Status: In Stock, Used Stock
Select:
More than 50 in stock
£37.71 ex VAT
£45.25 inc VAT
Toshiba's Canvio Basics for the PC requires only a single step to start saving and transporting important files, plug it in. With no software necessary to install, the Canvio Basics portable hard drive offers a hassle-free, high capacity storage solution right out of the box.
A sleek solution with plenty of storage capacity for the growing amount of digital content, from photos and videos to music and documents, the Canvio Basics offers an intelligent combination of data protection, portability, and simplicity. The one plug ease-of-use is complemented by the drive's stylish design, courtesy of a glossy finish and soft, rounded edges. Despite its light weight design and diminutive size, the Canvio Basics can add peace of mind by keeping files safe with its internal shock sensor and Ramp Loading technology.
Beyond its technical capabilities, the practicality of the Canvio Basics portable hard drive is evident in the drive's pocket-sized form factor which not only makes it easy to carry but also conforms to Toshiba's environmental efforts to reduce materials used in production. In addition, the Canvio Basics' packaging is made from 100 percent recyclable materials.
Toshiba Canvio Basics - hard drive - 1 TB - USB 3.0
Hard drive - external (portable) - NTFS formatted, LED power indicator
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
78 mm x 109 mm x 14 mm
149 g
1 TB
USB 3.0
78 mm
109 mm
14 mm
149 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows 7 / 8.1 / 10
1 x USB cable - USB Type A to micro-B - external
Plug and Play
Enclosure Colour
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DC8F 040928
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £30.91
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Form Factor: 2.5"
Capacity: 1TB
Interface: USB 3.0
Brand: Toshiba
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
