Product
Toshiba 16GB FlashAir W-04 UHS-I Class 3 SDHC Card
Quicklinx: D0B1WS00 Mfr#: THN-NW04W0160E6
Type: SDHC Memory Card
Capacity: 16GB
SD Speed Class: UHS-I U3 / Class10
£27.53 ex VAT
£33.03 inc VAT
The FlashAir SD card features an advanced processor design and delivers enhanced wireless performance as well as standard SD memory card functionality. Now it has even greater flexibility thanks to the integrated Eyefi Connected feature that prevents a camera automatically powering off when wirelessly connecting with FlashAir. Built-in wireless LAN functionality allows data stored on the card to be transferred to external devices.
  • Easy wireless LAN setup
    You do not need any drivers, software or cables. Just slide your FlashAir SD card into your camera or camcorder and setup the wireless LAN function using a PC, tablet or smartphone.
  • Low power consumption
    Optimized for battery powered devices, the wireless function is switched ON only when necessary, keeping the power consumption low.
Toshiba FlashAir W-04 - wireless memory card - 16 GB - SDHC
Wireless memory card
SDHC Memory Card
Interface Type
IEEE 802.11 b/g/n
Storage Capacity
16 GB
Speed Rating
UHS-I U3 / Class10
Encryption Algorithm
AES, TKIP, WPA, WPA2, WEP
Apple MacOS X 10.7 - 10.10, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
5 years warranty
Storage Capacity
16 GB
Compatibility
Non-specific
SD Speed Class
UHS-I U3 / Class10
Read Rate
Up to 90 MB/s
Write Rate
Up to 70 MB/s
SDHC Memory Card
Interface Type
IEEE 802.11 b/g/n
X-ray-proof, Wireless LAN Access Point mode (WLAN AP), Eyefi Connected
Limited warranty - 5 years
24 mm
2.1 mm
32 mm
2 g
-25 °C
85 °C
Capacity: 16GB
Brand: Toshiba
Price Range Ex VAT: 0 - 50
