The Toshiba EXCERIA PRO M401 microSD series is excellent for transferring 4K Ultra HD videos or high-resolution photographs. With up to 80 MB/s read speed for your shooting and 90 MB/s write speed for faster file transfer, it is just perfect for fast action photos and videos.
High write speed for your action shots
The Toshiba EXCERIA PRO series has been designed for use by the most demanding professional photographers. The cards offer today's highest write speed for the continuous shooting of pictures in RAW and JPEG format and full HD video capture. -
High read speed to save your time
Unrivaled file transfer speed from your card to your computer to speed you workflow. Store, review and edit your photos and video more quickly. -
Controller
The EXCERIA PRO SD cards integrate a controller compliant with UHS-II, the ultra-high-speed serial bus interface defined in SD Memory Card Standard. -
Secure your file
With the Toshiba write-protect feature, you can prevent accidental overwrites.
- Toshiba EXCERIA PRO M401 - flash memory card - 16 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 16 GB
- Speed Rating
- UHS Class 3 / Class10
- Technology
- NAND Flash
- Included Memory Adapter
- microSDHC to SD adapter
- 5-year warranty
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Speed Class
- Read Rate
- Up to 95 MB/s
- Write Rate
- Up to 80 MB/s
- Form Factor
- Technology
- NAND Flash
- Limited warranty - 5 years
- 11 mm
- 15 mm
- Thickness
- 1 mm
- 0.4 g
