Product
Toshiba 16GB Exceria Pro M401 U3 microSD Card
Quicklinx: D8HDWS00 Mfr#: THN-M401S0160E2
The Toshiba EXCERIA PRO M401 microSD series is excellent for transferring 4K Ultra HD videos or high-resolution photographs. With up to 80 MB/s read speed for your shooting and 90 MB/s write speed for faster file transfer, it is just perfect for fast action photos and videos.
  • High write speed for your action shots
    The Toshiba EXCERIA PRO series has been designed for use by the most demanding professional photographers. The cards offer today's highest write speed for the continuous shooting of pictures in RAW and JPEG format and full HD video capture.
  • High read speed to save your time
    Unrivaled file transfer speed from your card to your computer to speed you workflow. Store, review and edit your photos and video more quickly.
  • Controller
    The EXCERIA PRO SD cards integrate a controller compliant with UHS-II, the ultra-high-speed serial bus interface defined in SD Memory Card Standard.
  • Secure your file
    With the Toshiba write-protect feature, you can prevent accidental overwrites.
Toshiba EXCERIA PRO M401 - flash memory card - 16 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
16 GB
Speed Rating
UHS Class 3 / Class10
NAND Flash
Included Memory Adapter
microSDHC to SD adapter
5 years warranty
Flash memory card
Storage Capacity
16 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 95 MB/s
Write Rate
Up to 80 MB/s
NAND Flash
Limited warranty - 5 years
11 mm
15 mm
Thickness
1 mm
0.4 g
