Put the Toshiba N302 memory card in your digital camera or your mobile device and expand your storage. You can take many pictures with your smartphone or store songs and videos.
Capture your precious moments
Great for enthusiastic photographers, this memory card provides the speed and capacity you need to catch the perfect moment in Full HD. -
Secure your files
With the Toshiba write-protect feature, you can prevent accidental overwrites. Also, no worries at the airport security check, the card safely protects your precious memories from the radiation of the security scanners.
- Toshiba EXCERIA N302 - flash memory card - 16 GB - SDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDHC UHS-I Memory Card
- Storage Capacity
- 16 GB
- Speed Rating
- UHS-I U3 / Class10
- 5-year warranty
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Speed Class
- Read Rate
- Up to 90 MB/s
- Form Factor
- Write protection switch, X-ray-proof
- Limited warranty - 5 years
- 24 mm
- 32 mm
- 2.1 mm
- 2 g
- -25 °C
- 85 °C
