BOOST YOUR SPEED AND PERFORMANCE
Boosting your daily boot-up speed and improving performance has never been easier. Upgrade your PC with an A100 Solid State Drive based on Toshiba's 3-bit-per-cell flash technology and experience high-speed boot up, fast system responsiveness and silent operation.
PERFORMANCE FOR EVERYDAY USE
Upgrade to a fast, efficient Toshiba A100 Solid State Drive with capacities up to 240 GB thanks to 3-bit-per-cell flash technology. A solid state drive reduces OS boot time and speeds up your computing system responsiveness rates by leaps and bounds. That's so you can enjoy more of what you want to browse and to create.
SPEEDY BOOT-UP AND PERFORMANCE
The SSD A100 uses 3-bit-per-cell flash to maximise storage capacity, without sacrificing speed. Thanks to advanced-speed and SLC Write Cache technology your system will be more responsive. From the first boot, you’ll experience speedier web browsing, emailing, media playback and more.
ONE STEP AHEAD
Trim Support keeps write speeds high by emptying unneeded stored data in advance. When new data needs to be stored, all is clear for swift operations.
LINING THINGS UP FOR MORE SPEED
Native Command Queuing (NCQ) realigns commands on the fly to optimise SSD access. This further accelerates the speed of data read/write performance.
QUALITY YOU CAN TRUST
Toshiba is the inventor of flash memory, and has a well-earned worldwide reputation for producing high-quality technology. Toshiba SSDs are based on NAND Flash technology and incorporate Toshiba controllers to achieve industry-leading levels of performance and reliability. Not only that, we are so confident of the longevity, we back it up with a 3 year warranty.
Performance for everyday use
Upgrade to a fast, efficient Toshiba A100 Solid State Drive thanks to 3-bit-per-cell flash technology. A solid state drive reduces OS boot time and speeds up your computing system responsiveness rates by leaps and bounds. That's so you can enjoy more of what you want to browse and to create. -
Speedy boot-up and performance
The SSD A100 uses 3-bit-per-cell flash to maximize storage capacity, without sacrificing speed. Thanks to advanced-speed and SLC Write Cache technology your system will be more responsive. From the first boot, you'll experience speedier web browsing, emailing, media playback and more. -
One step ahead
Trim Support keeps write speeds high by emptying unneeded stored data in advance. When data needs to be stored, all is clear for swift operations. -
Lining things up for more speed
Native Command Queuing (NCQ) realigns commands on the fly to optimize SSD access. This further accelerates the speed of data read and write performance.
- Toshiba A100 - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Native Command Queuing (NCQ), TRIM support, Garbage Collection technology, Adaptive Size SLC Write cache technology, Read Only Mode, Toshiba TC58NC1010 controller, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 37.5 g
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 37.5 g
Performance
- SSD Endurance
- 30 TB
- Internal Data Rate
- 550 MBps (read) / 480 MBps (write)
- 4KB Random Read
- 87000 IOPS
- 4KB Random Write
- 82000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3.4 Watt (active) , 440 mW (idle)
- Limited warranty - 3 years
- 0 °C
- 65 °C
