Tile Mate - Item Finder
Quicklinx: D81TWS00 Mfr#: RT-05001-EU
Even better than the first time, the Tile Gen 2 will let you find your keys, handbag or any other item attached to the Tile using your smartphone, as well as let you locate your lost phone using your Tile.
How it works
  • Attachment: The Tile's compact, lightweight and innovative design means you can easily attach it to most objects that you're worried you might lose. For example, it easily hooks onto your house, car or bike keys, but can also be attached to your laptop, bike or handbag, even your suitcase.
  • Detection: Once your smartphone is within 100-foot Bluetooth signal of the Tile it'll start the hunt. As you get closer to the lost object the signal will get stronger and the distinctive melody (up to 88 decibels) of the Tile can be heard.
Use Tile to Find Your Phone
On those days you can't find your phone you can use the Tile to locate it. Just double tap the "e" button on the Tile and your phone will ring (even if it's on silent) as long as it's within 100-foot Bluetooth range.
Easy app
The app is simple to set up and straightforward to use. It'll automatically record the last time and place you had your missing item, so you can pinpoint it on a map. It also lets you use other devices to sign in to your Tile app and enables you to reach out to the wider Tile Community to find your your missing possessions.
Durable design
The Tile is built to last around 1 year or 8765 hours and is water resistant (IP5) to prevent it from damaging when caught in the rain.
Compatible with
  • iOS: iPhone (Released 2011 or later), iPad (Released 2012 or later), iPad Mini iPod Touch, Apple Watch
  • Android: Android: Samsung Galaxy (S5 or later), Samsung Note (4 or later), Nexus (4 or later), OnePlus (one or later), HTC one (M8 or later), Motorola Moto X, and most Android devices equipped with Android 4.4 (Kitkat) or later and Bluetooth 4.0 or later
  • Dimensions H34 x W34 x D4.65mm Weight 6.1g
  • Tracks your stuff
    Attach a Tile to an item and locate it by sound when it's close but out of sight. If you still can't find your Tiled item, use the Tile app to see its last known location on a map, or leverage the Tile community to find it for you.
  • Maintenance-free
    They designed Tile to run a full year with zero upkeep - no battery replacement, no charging. When it's time for a new Tile, they will notify you about their reTile program - an easy way to upgrade your Tiles to the good technology.
  • Find your phone
    When you can't find your phone nearby, press Tile to loudly ring your lost phone - even on silent. You can also log in to their website to see its last known location, make it ring or to send a lock-screen message.
Tile Mate - wireless security tag for mobile phone
Wireless security tag
Intended For
Mobile phone
Integrated Components
Speaker
Wireless Interface
Bluetooth
Protection
Waterproof
3.4 cm 3.4 cm
Thickness
0.465 cm
6.1 g
1-year warranty
Intended For
Mobile phone
Speaker
Wireless Interface
Bluetooth
Max Operating Distance
30.48 m
Protection
Waterproof
3.4 cm
3.4 cm
6.1 g
Thickness
0.465 cm
IP5
1-year warranty
