Doom Edition Gaming Headset:
- DOOM edition enables Launch synergy and game optimization.
- Exclusive Worldwide partnership with the iconic licence : the pioneer of FPS games.
HD Audio with the Most Powerful Bass on Console EVER thanks to 60mm drivers
- Official licensed gaming headset for a perfect sound on Xbox One and PC windows 10!
- Premium, powerful 60 mm drivers. Feel the intensity of the game thanks to overboosted Bass frequencies! The most optimized frequency response curve for Bass / Medium / High frequencies: hear FIRST / react FIRST / kill FIRST!
- The best of our audio expertise, taking your performance to the next level.
Y Sound Commander : A Unique Instrument Panel plugged into Xbox One gamepad
- Instant in-game access to features and precise indications.
- 7.1 Virtual Surround Sound technology allows gamers to precisely pinpoint the location of each sound, ensuring maximum immersion in the battlefield!
- Power Bass so that users can feel the intensity of the explosions in game.
- Backlighted Volume Status for a quick and precise control’s adjustments.
- Voice feedback function.
- Technology powered by Thrustmaster / Texas instrument / AM3D.
The alliance of Comfort and isolation:
- 100% memory foam cushions on both ear and headband cushions to provide outstanding comfort: large, ultra-soft ear pads and a headband covered in thick, soft foam padding for extreme comfort and effective passive isolation.
- Double electro-acoustic bass amplification, thanks to the earpieces’ unique design, combined with electronic bass boost built into the controller.
High performance Microphone!
- Voice targeting microphone, designed to target just your voice for the most effective communication with your teammates.
- Microphone is detachable and adjustable, to adapt to every player’s head size and shape.
Full Compatibility
- Plug’n’Play on Xbox One and PC windows 10.
- Fully compatible* with Windows 10 on PC / Surface / windows phones.
- Product reference
- Y-350X 7.1 Powered DOOM edition
- Packaging
- Closed Box
- Description
- Gaming headset
- Packaging dimensions
- 11.5 / 24.7 / 23.5
- (width/height/depth) (cm)
- Product weight (g)
- 806
- Pieces/inner carton
- NO
- Pieces/master carton
- 5
- Master carton dimensions
- 26.5 / 25 / 59.5
- Empty master carton weight (kg)
- 650
- Weight of one empty master carton and two empty inner cartons (kg)
- 5.5
- Weight of one master carton with products (kg)
- 4.75
- Capacity/20' container (pieces)
- 3360
- Capacity/40' container (pieces)
- 7200
- Capacity/40' HQ container (pieces)
- 8100
- Country of origin
- Designed in Europe /
Product reference
Packaging
- Closed Box
- Gaming headset
Product weight (g)
- 806
Pieces/inner carton
- NO
- 5
- 26.5 / 25 / 59.5
- 650
- 5.5
- 4.75
- 3360
- 7200
- 8100
Country of origin
- Made in China
