The Y-300CPX is an amazing universal USB audio gaming headset that features amplified bass performance.
Audio expertise
Incredible audio sensations, thanks to the stable frequency response curve optimized for your gaming sessions, with perfect balance between bass, mids and treble. -
Designed for comfort
Special design that provides outstanding comfort, with large and ultra-soft ear pads and effective passive isolation. -
High-performance microphone
Unidirectional microphone, designed to target only your voice, for effective communication with your teammates. The microphone is detachable and adjustable, to adapt to every player's head size and shape. -
Advanced controls
Multi-functional controller on the cable, allowing you to adjust the audio level of the game and of voices independently. Advanced customization of your microphone's gain level. Adjust the gain precisely for your voice, so that you'll be perfectly understood by your teammates.
- ThrustMaster Y-300CPX - DOOM Edition - headset
- Product Type
- Headset - wired
- Recommended Use
- Game console, computer
- Additional Functions
- Amplifier
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Bass, microphone gain, volume control
- Designed For
- Xbox 360, Xbox One; Sony PlayStation 3, Sony PlayStation 4
- Product Type
- Headset - wired
- Amplifier
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- Diaphragm
- 50 mm
- In-Cord Volume Control
Microphone
- Boom
- Mono
- Audio Input Details
- Uni-directional
Remote Control
- Controls
- Connector Type
- Headset
Cable
- Cable Length
- 4 m
- Cable Details
- Headset cable
- Designed For
- Xbox 360, Xbox One , Sony PlayStation 3, Sony PlayStation 4
