Thrustmaster Y250C PC Gaming Headset (Wired)
Quicklinx: D783WS00 Mfr#: 2960741
This stereo gaming headset provides pure analog audio for accurate, optimal reproduction of the sound of games on your PC. Enjoy crystal-clear audio, via premium drivers: hear everything, react quickly! Unidirectional mic is designed to accurately target just your voice, for effective communication with your teammates.
  • Audio expertise
    Enjoy crystal-clear audio, via premium drivers: hear everything, react quickly! At last, you can properly hear the bass frequencies from explosions! Audio sensations are even more real than real life, thanks to the stable frequency response curve optimized for your gaming sessions, with perfect equilibrium between bass, mids and treble.
  • High-performance microphone
    Unidirectional mic is designed to accurately target just your voice, for effective communication with your teammates. Microphone is detachable and adjustable, to adapt to every player's head size and shape. Adjust the gain precisely for your voice, so that you'll be perfectly understood by your teammates.
  • Designed for comfort and performance
    Unique design, crafted by ThrustMaster's team provides outstanding comfort: large, ultra-soft ear pads and a headband covered in thick, soft foam padding for extreme comfort during long gaming sessions and reliable, effective passive isolation. Exclusive acoustic bass amplification system is provided thanks to the earpieces' unique design.
  • Advanced controls
    Controls are at your fingertips, thanks to the multifunctional controller on the cable: no need to fumble with your PC's settings.
ThrustMaster Y-250C - headset
Headset - wired
Recommended Use
Game console, portable electronics, computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 10 - 25000 Hz
Microphone
Detachable - boom
Controls
Microphone on/mute, phone/music mode
Headset - wired
364 g
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
10 - 25000 Hz
Diaphragm
50 mm
In-Cord Volume Control
Microphone
Boom
Sensitivity
-50 dB
Audio Input Details
Uni-directional
Remote Control
Controls
Connector Type
Headset
Cable Details
Headset cable - 2.8 m
