Thrustmaster TMX Racing Wheel - Forza Horizon 3 & Forza Motorsport 6 XBOX One
Quicklinx: CDF0WS00 Mfr#: 5027757096785
Equipped with a high-performance force feedback motor offering adjustable intensity and a rotation angle ranging from 270° to 900°, the TMX Force Feedback delivers a realistic and versatile racing experience. The controller’s versatility benefits all players, whether beginners or seasoned pilots, with all types of tracks, cars and races. Another example of this racing wheel’s versatility is its force feedback motor, designed by Thrustmaster’s development teams to offer performance suited to demanding players, while also remaining accessible to less experienced drivers. The motor features a mixed belt-pulley and gears system with metal ball-bearing axle. The result is a balanced combination of performance, robustness and precision. With 12-bit resolution – i.e. 4096 values on the wheel’s steering axis – provided by an optical sensor, this racing wheel also offers extreme precision, delivering highly realistic racing sensations. The racing wheel features a robust and adjustable attachment system, compatible with all mounts (desks, tables, cockpits, etc.).
Thanks to Xbox One-certified embedded software, the controller is automatically recognized by the video game console, which also ensures full compatibility with the menus in all racing games supporting racing wheels. And with the Thrustmaster drivers available for free download from http://ts.thrustmaster.com/, the racing wheel is also compatible with Windows (10, 8, 7 and Vista).
Official Racing Simulator Designed for Xbox One & Windows
  • 900° force feedback racing wheel.
  • Realistic 11"/28 cm wheel.
900° force feedback base
  • Drive system with adjustable force feedback lets you feel every detail while you’re racing (the road or track’s relief, loss of tire grip, braking, bumps and impacts, etc.).
  • Rotation angle adjustable from 270° to 900°!
  • Very precise wheel: optical reading with 12-bit resolution (i.e. 4,096 values on the wheel’s steering axis)
  • Mixed belt-pulley and gears system (smoother, more fluid and less noisy than helical gears) with metal ball-bearing axle (for enhanced sturdiness).
  • Internal memory and upgradeable firmware.
  • Robust and versatile attachment system, compatible with all mounts (desks, tables, etc.)
  • Compatible with the T3PA* and T3PA-PRO* pedal sets (Thrustmaster 3 Pedals Add-on)
  • Compatible with the Thrustmaster TH8A* shifter.
Realistic "competition" wheel design
  • 11"/28 cm in diameter, with an ergonomic design perfectly adapted for all racing games (GT, F1, NASCAR, RALLY, etc.)
  • Rubber-coated wheel grips.
  • 2 large, wheel-mounted sequential paddle shifters 5"/13 cm tall – 100% metal – Tact switch with life cycle exceeding 500,000 activations.
  • Built-in official buttons for Xbox One: Xbox Guide button, View and Menu Switch between the game and the system, navigate through the system’s menus, access social functions, etc.
  • Comprehensive driving gear 12 action buttons + 1 directional pad.
Xbox One certified embedded software
  • Official embedded software: the racing wheel is automatically recognized by the Xbox One.
  • Compatible in the console’s menus.
  • Compatible with all Xbox One racing games supporting racing wheels.
Also compatible with PC
  • PC compatibility (Windows 10/8/7/Vista) ensured thanks to the Thrustmaster drivers available for download from the http://ts.thrustmaster.com/ website. The drivers allow you to make sure that you always have the latest firmware version available for the racing wheel.
Large, optimized pedal set
  • Pedals with wide foot rest.
  • Each pedal’s angle of inclination can be adjusted.
  • Brake pedal with progressive resistance.
*Sold Separately
  • Intense fun at your fingertips
    When it comes to handling, the racing wheel's diameter is suited to all types of racing games. Its rubber-coated wheel grips offer perfect comfort. When it comes to ergonomics, everything has been designed to ensure that the two large, 5" tall, 100% metal wheel-mounted sequential paddle shifters are within easy reach, just like the 12 action buttons and the directional pad.
  • Exceptional efficiency at your feet
    The TMX Force Feedback's features a wide 2-pedal pedal set that delivers efficient acceleration and braking: each pedal's angle of inclination can be adjusted, and for greater realism, the brake pedal also offers progressive resistance.
Thrustmaster TMX Force Feedback - wheel and pedals set - wired
Wheel and pedals set
Wired
PC, Microsoft Xbox One
Wired
Game Controller (1st) Details
Wheel
Buttons Qty
12
Controls
D-pad, 2 gear shift levers
Force feedback, rubber side grips, 28 cm wheel diameter, 270 to 900° wheel rotation, 2 sequential paddle shifters
Game Controller (2nd) Details
Pedals
Foot rest, adjustable pedal angle, brake pedal progressive resistance
Microsoft Windows Vista / 7 / 8 / 10
