Thrustmaster T150 RS Pro Racing Wheel UK
Quicklinx: CNM1WS00 Mfr#: 4168059
Type: Wheel
49 in stock
£183.33 ex VAT
£219.99 inc VAT
Realistic « competition» wheel design
11"/28 cm in diameter, with an ergonomic design perfectly adapted for all racing games (GT, F1, NASCAR, RALLY, etc.) Rubber-coated wheel grips 2 large, wheel-mounted sequential paddle shifters ( 5"/13 cm tall – 100% metal – Tact switch with life cycle exceeding 500,000 activations) Built-in official buttons for PlayStation®4 system (PS/SHARE/OPTIONS) Access social functions, switch between the game and the system, navigate through the system’s menus, etc. Comprehensive driving gear: 13 action buttons (including 2 on the base) + directional buttons
1080° force feedback base
Drive system with adjustable force feedback lets you feel every detail while you’re racing (the road or track’s relief, loss of tire grip, braking, bumps and impacts, etc.). Rotation angle adjustable from 270° to 1080°! Very precise wheel: optical reading with 12-bit resolution (i.e. 4,096 values on the wheel’s steering axis) Mixed belt-pulley and gears system (smoother, more fluid and less noisy than helical gears) with metal ball-bearing axle (for enhanced sturdiness) Internal memory and upgradeable firmware Robust and versatile attachment system, compatible with all mounts (desks, tables, etc.)
Includes: T3PA 3-pedal pedal set
100% metal pedals and internal structure Conical Rubber Brake MOD included (with ultra-progressive resistance at the end of the brake) 3 fully adjustable pedals (spacing, inclination and height)
Compatible with the Thrustmaster TH8A shifter*
*sold separately
PlayStation®4-certified embedded software and sliding switch for PS4™/PS3™
Official embedded software: the racing wheel is automatically recognized by the PS4™ system Compatible in the system’s menu Sliding switch for PS4™/PS3™ for optimal compatibility on both systems
Also compatible with PC
PC compatibility (Windows 10/8/7/Vista) ensured thanks to the Thrustmaster drivers available for download from the http://support.thrustmaster.com/ website. The drivers allow you to make sure that you always have the latest firmware version available for the racing wheel.
  • 1080-degree force feedback
    Drive system with adjustable force feedback lets you feel every detail while you're racing (the road or track's relief, loss of tire grip, braking, bumps and impacts, etc.). Rotation angle is adjustable from 270 degrees to 1080 degrees! T150 features a very precise wheel, mixed belt-pulley and gears system. Smoother, more fluid and less noisy than helical gears with metal ball-bearing axle (for enhanced sturdiness).
  • Large, optimized pedal set
    Pedals with wide foot rest. Each pedal's angle of inclination can be adjusted. Features a brake pedal with progressive resistance.
  • Realistic wheel
    Access social functions, switch between the game and the system, navigate through the console's menus with an ergonomic design perfectly adapted for all driving games. Features rubber-coated wheel grips and 2 large, wheel-mounted sequential paddle shifters.
  • Comprehensive driving gear
    Comes with 13 action buttons (including 2 on the base) + 1 D-Pad.
Type: Wheel
Brand: Thrustmaster
Price Range Ex VAT: 150 - 300
