This Thrustmaster T.16000M joystick uses exclusive high-precision technology to bring you a breathtaking experience in 3D games!
The T.16000M can be used by both left-handed and right-handed users, and features 3D Hall Effect magnetic sensors that are 256 times more accurate than those used in regular joysticks. It also has 16 buttons and 4 independent axes, as well as a hand-rest for comfortable gaming no matter how long you play!
The affordable Thrustmaster T.16000M is a high-precision joystick that will revolutionise your PC gaming!
Type: Joystick
Compatible platforms: Windows XP, Windows Vista
Connectivity: USB
Controls: 16
Other features:
Switch for setting the 12 base buttons to left-handed or right-handed use
4 independent axes
Rudder control by rotating the handle
Brake trigger (civil flight) or rapid fire (military flight)
Multidirectional hat switch (for panoramic view)
Wide hand-rest reduces tiredness
Filled base for greater stability
Wireless: Yes
System Requirements: Self-powered through USB
- ThrustMaster T.16000M - joystick - wired
- Product Type
- Joystick
- Connectivity Technology
- Wired
- Buttons Qty
- 16
- Designed For
- PC
- Product Type
- Joystick
- Wired
- Buttons Qty
- 16
- Interface
- USB
- 1 x USB - 4 pin USB Type A
- Plug and Play
- Designed For
- PC
