As an addition to the Core V Series, the Thermaltake Core V21 is a quadrate micro M-ATX-based chassis that offers an endless stackable and flexible thermal solution. It allows externally-modular upgrades for enthusiasts to create dual systems. Designed for use in either a vertical or horizontal orientation on the motherboard, users can customize the chassis for the best viewing presentation. A 200mm fan on the front panel ensures that the Core V21 delivers outstanding cooling performance with compatibility for extensive DIY/AIO LCS, further enhancing the reputation that the air cooling units of the series has become renowned for. Guaranteed to be an immensely powerful system, the Core V21 also has the ability to accommodate various overclocking components to boost performance even further where it counts!
Vertical or horizontal motherboard placement
The Core V21 is designed for use in either a vertical or horizontal orientation on the motherboard. Built for customization that reflects the enthusiast's personality, it allows for adjustments to the chassis for the best viewing presentation while ensuring outstanding cooling performance. A removable PSU dust filter is embedded in the bottom panel of the chassis. Additionally, shockproof rubber gaskets on the PSU bracket help to minimize noise during operation. -
Stackable and flexible thermal solution
With its endless stackable design, the Core V21 is in a class above the rest. Virtually limitless utility is possible. It's the first expandable system that allows enthusiasts to incorporate externally -modular upgrades. Stacked together, the chassis opens up space to expand the liquid cooling system, the storage solutions, or even create dual systems, thereby allowing for a dedicated top/bottom set-up for pure cooling. The maximum radiator length supported is 600mm at the front of the stack. -
Remarkable expansion
Designed for high-end gaming system compatibility, the Core V21's modular drive racks allow gamers to easily install up to six data storage devices, a dual expansion slot VGA up to 350mm in length, and a tower CPU cooler up to 185mm in height. Even with a high-wattage PSU of up to 200mm in length, there's still plenty of space available for cable management. Moreover, two 240mm radiators can be installed on top of the chassis, delivering superior cooling performance. -
Optimized ventilation
With its exceptional cooling ability, the Core V21 offers various mounting points to support all types of cooling systems, including DIY/AIO liquid-cooling systems and air-cooling units. A large 200mm fan is preinstalled on the front to guarantee that any type of gaming system can be accommodated. -
Chambers concept
The Core V21 is optimized for space management. It is divided into two main chambers: the upper chamber is made for cooling performance and efficiency, while the lower one is made for PSU and drive bays. Thanks to the removable 2.5"/3.5" drive device racks, there is plenty of flexibility to gain the maximum interior space when needed for advanced cooling performance or liquid systems build.
- Thermaltake Core V21 - tower - micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x microphone , 1 x headphones
- Supported Motherboards
- microATX, Mini-ATX
- System Cabinet Features
- Removable dust filter, supports 120 mm radiator in rear, supports 120/140/240 mm radiator in front panel, supports 2 x 120/140 mm radiators in top, supports 140/280 mm radiator in top, supports 120/140/240/280 mm radiator in side panel, supports 1/2", 3/8",1/4" water tube, vertical/horizontal motherboard orientation, stackable
- Power Device
- No power supply (PS/2)
- 33.6 cm x 32 cm x 42.4 cm
- 6.5 kg
- Form Factor
- Tower
- Max Mainboard Size
- Micro ATX
- Internal Bays Qty
- 6
- Black
- Cooling System
- Front: 200 x 200 x 30 mm fan x 1 / intake / 800 rpm / 13 dBA / 1 x 200 mm or 2 x 140 mm or 2 x 120 mm fan supported , Top: 140 mm fan mount x 2 / 4 x 120 mm fan supported , Rear: 140 mm fan mount x 1 / 1 x 120 mm fan supported , Bottom: 120 mm fan mount x 2 , Side: 140 mm fan mount x 2 / 2 x 120 mm fan supported
- CPU Cooler Max Height
- 185 mm
- Video Card Max Length
- 350 mm
- Expansion Bays
- 3 (total) / 3 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 5
- 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
- Power Device
- No power supply
- Specification Compliance
- PS/2
- 33.6 cm
- 32 cm
- 42.4 cm
- 6.5 kg
