Techair UltraBook 2 in 1 Sleeve & Case for Laptops / Ultrabooks up to 13.3"
Quicklinx: 8HJKWS00 Mfr#: TAUBS003
Techair 2 in 1 sleeve is a slimline contemporary case designed to carry and protect your Ultrabook. The innovative design allows you to detach the accessories compartment and travel light when needed. The Ultrabook compartment is fur lined to and additional pockets provide space for accessories and power supply.
Techair 2 in 1 sleeve is a slimline contemporary sleeve designed to carry and protect Ultrabooks and other slim 12"-13.3" laptops. This innovative product has a detachable accessories compartment allowing you to travel light when needed. When on the move your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrasion free protection. An additional pocket provides space for accessories and power supply. The luxury webbing handle and shoulder strap plus the durable material all add up to making a great light weight product that will compliment your UltraBook.
techair TAUBS003 - notebook carrying case
Notebook carrying case
Product Material
900 x 1200D polyester
35 cm x 5.5 cm x 24 cm
620 g
Notebook Compatibility
13.3"
Zippered, removable laptop sleeve, removable shoulder strap, adjustable shoulder strap, shower proof
Carrying Strap
Hand grip, shoulder carrying strap
Product Material
35 cm
5.5 cm
24 cm
620 g
13.3"
Notebook Compatibility Dimensions
33 cm x 23 cm x 2 cm
Additional Compartments
Cable, documents, personal accessories
Carrying Strap
Limited warranty: - lifetime
