Techair 2 in 1 sleeve is a slimline contemporary case designed to carry and protect your Ultrabook. The innovative design allows you to detach the accessories compartment and travel light when needed. The Ultrabook compartment is fur lined to and additional pockets provide space for accessories and power supply.
Techair 2 in 1 sleeve is a slimline contemporary sleeve designed to carry and protect Ultrabooks and other slim 12"-13.3" laptops. This innovative product has a detachable accessories compartment allowing you to travel light when needed. When on the move your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrasion free protection. An additional pocket provides space for accessories and power supply. The luxury webbing handle and shoulder strap plus the durable material all add up to making a great light weight product that will compliment your UltraBook.
- techair TAUBS003 - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 900 x 1200D polyester
- 35 cm x 5.5 cm x 24 cm
- 620 g
- Notebook Compatibility
- 13.3"
- Zippered, removable laptop sleeve, removable shoulder strap, adjustable shoulder strap, shower proof
- Carrying Strap
- Hand grip, shoulder carrying strap
- Limited lifetime warranty
- Product Type
- Product Material
- 35 cm
- 5.5 cm
- 24 cm
- 620 g
- 13.3"
- Notebook Compatibility Dimensions
- 33 cm x 23 cm x 2 cm
- Additional Compartments
- Cable, documents, personal accessories
- Carrying Strap
- Black
- Limited warranty: - lifetime
