Techair TAUBA004v2 13.3" Notebook Carry Case
Quicklinx: CKZ6WS00 Mfr#: TAUBA004v2
The Techair Attaché is a slimline contemporary case specifically designed to carry and protect Ultrabooks. Your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrashion free protection. An additional pocket provides space for accessories and power supply.
The Techair Attaché is a slimline contemporary case specifically designed to carry and protect Ultrabooks and other slim 12"-13.3" laptops. When on the move your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrasion free protection. An additional pocket provides space for accessories and power supply. The luxury webbing handles and shoulder strap plus the durable material all add up to making a great light weight product that will compliment your UltraBook.
techair Ultrabook Laptop Bag - notebook carrying case
Notebook carrying case
Product Material
Polyester
34.5 cm x 4 cm x 23.5 cm
360 g
Notebook Compatibility
13.3"
Notebook Supported Sizes
12" - 13.3" / 30.5 cm - 33.8 cm
Zipper pockets, faux fur inner lining, premium webbing shoulder strap protective foam
Carrying Strap
Hand strap, adjustable shoulder strap
Product Material
Polyester
34.5 cm
4 cm
23.5 cm
360 g
13.3"
Notebook Compatibility Dimensions
33 cm x 23 cm x 2.5 cm
Carrying Strap
Closure Type
Zipper pocket
Compartments Quantity
2
Protective foam
Limited warranty: - lifetime
