Techair Samsung Tab A 10.1" Rugged Case Black
Quicklinx: DFYXWS00 Mfr#: TAXSGA022
This protective cover is perfect for those that play rough and want reliable protection. The combination of rigid plastic and shock-absorbing silicone ensures your machine is always protected while the built in screen cover keeps your touchscreen protected and scratch free.
techair - protective case for tablet
Protective case for tablet
Screen Size Compatibility
10.1"
18.5 cm x 2 cm x 27.5 cm
380 g
Material
Silicone, polycarbonate
Samsung Galaxy Tab A (2016) (10.1 in)
18.5 cm
2 cm
27.5 cm
380 g
Rugged
Material
Carrying Case
Protective case
Recommended Use
For tablet
10.1"
Protection
Shockproof, scratch-resistant
Inner Dimensions
15.53 cm x 0.82 cm x 25.42 cm
Protective screen
Cover Features
Stand function
Lifetime
