If you're looking for a case that will keep your iPhone protected then look no further. The rugged pro protective case from techair encases your phone with impact protection technology, additional corner bumpers add further protection. techair has even included a clip-on holster. Now that's function with emotion!
- techair classic pro - protective case for tablet
- Product Type
- Protective case for tablet
- Screen Size Compatibility
- 10.2"
- 19.3 cm x 2.3 cm x 26.1 cm
- 390 g
- Material
- Silicone, polycarbonate
- Black
- Limited lifetime warranty
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
- 19.3 cm
- 2.3 cm
- 26.1 cm
- 390 g
- Rugged
- Material
- Black
Carrying Case
- Protective case
- Recommended Use
- For tablet
- 10.2"
- Protection
- Scratch-resistant, shock-resistant
- Additional Compartments
- Stylus
- Inner Dimensions
- 17.4 cm x 0.8 cm x 25.1 cm
- Cover Features
- Stand function
- Lifetime
- Designed For
