This beautiful collection of laptop cases brings a contemporary slant on classic design. Each case has been carefully crafted with a stylish approach to practicality. Constructed from quality materials, each case features a protective padded laptop section so you can be sure that your laptop is safe. Carrying is made comfortable with a cushioned shoulder pad. The length of the shoulder strap is adjustable and the strap can be removed completely if desired. The trolley strap on the back of the case allows you to securely attach the case to luggage for easy transportation. Keeping belongings organised is easy with the rear document section and a selection of sized pockets designed for convenience, which are easily accessible in front zip down section and in the main compartment.
- Targus XL 17 - 18.4 inch / 43.1 - 46.7cm Deluxe Laptop Case - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Nylon, koskin
- 45.4 cm x 10.2 cm x 36.8 cm
- 1.37 kg
- Notebook Compatibility
- 18.4"
- Zippered, padded, mesh accessory pockets, removable pouch, removable shoulder strap, moulded handles
- Carrying Strap
- Hand grip, shoulder carrying strap
- Limited lifetime warranty
- Product Type
- Product Material
- Nylon, koskin
- 45.4 cm
- 10.2 cm
- 36.8 cm
- 1.37 kg
- 18.4"
- Notebook Compatibility Dimensions
- 44.1 cm x 4.4 cm x 30 cm
- Additional Compartments
- Mobile phone, PDA, memory card, credit cards, power adapter, documents, pens, personal accessories, mouse
- Carrying Strap
- Black
- Limited warranty: - lifetime
