Targus XL Notebook Case
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 3MK9WS00 Mfr#: CN317
This beautiful collection of laptop cases brings a contemporary slant on classic design. Each case has been carefully crafted with a stylish approach to practicality. Constructed from quality materials, each case features a protective padded laptop section so you can be sure that your laptop is safe. Carrying is made comfortable with a cushioned shoulder pad. The length of the shoulder strap is adjustable and the strap can be removed completely if desired. The trolley strap on the back of the case allows you to securely attach the case to luggage for easy transportation. Keeping belongings organised is easy with the rear document section and a selection of sized pockets designed for convenience, which are easily accessible in front zip down section and in the main compartment.
Targus XL 17 - 18.4 inch / 43.1 - 46.7cm Deluxe Laptop Case - notebook carrying case
Notebook carrying case
Product Material
Nylon, koskin
45.4 cm x 10.2 cm x 36.8 cm
1.37 kg
Notebook Compatibility
18.4"
Zippered, padded, mesh accessory pockets, removable pouch, removable shoulder strap, moulded handles
Carrying Strap
Hand grip, shoulder carrying strap
Product Material
Nylon, koskin
45.4 cm
10.2 cm
36.8 cm
1.37 kg
18.4"
Notebook Compatibility Dimensions
44.1 cm x 4.4 cm x 30 cm
Additional Compartments
Mobile phone, PDA, memory card, credit cards, power adapter, documents, pens, personal accessories, mouse
Carrying Strap
Limited warranty: - lifetime
