The Targus Wireless Optical Laptop Mouse is the perfect solution for users on the move or those who prefer a clutter-free workspace. Designed to fit comfortably in any size hand it provides perfect support for extended periods of use, whilst the integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The high definition optical sensor provides enhanced precision and accuracy, and extended battery life of up to 6 months.The low power indicator light will provide you with an early warning for when the batteries need changing. The mouse also comes with a micro USB receiver which is small enough to leave permanently plugged into your computer or using the built-in Stow-N-GoTM technology the USB receiver can be easily stored away into the mouse itself. *Battery life based on average usage per day and computing conditions.
Compatibility
Designed to work with PC, Mac or Netbook computers. -
High-Definition sensor provides up to 8 months of battery life. -
Optical Sensor technology
1000 DPI high-precision laser sensor technology accurately responds to mouse movements. -
Easy storage
Stow-N-Go USB receiver is small enough to store inside the mouse while traveling. -
Ergonomic
Ergonomically designed to lend hours of comfort in any size hand.
- Targus Wireless Optical Laptop - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- 5.7 cm x 10.5 cm x 4 cm
- 65 g
- Localisation
- European Union
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- Scrolling wheel, battery indicator
- OS Required
- Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- 5.7 cm
- 10.5 cm
- 4 cm
- 65 g
- Black
- Localisation
- European Union
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- 1000 dpi
- 1 x USB - 5 pin Micro-USB Type B
- Run Time (Up To)
- 6 months
- OS Required
- Limited warranty - 2 years
