Targus Wireless Optical Mouse - Black
Quicklinx: 8PYWWS00 Mfr#: AMW56EU
The Targus Wireless Optical Laptop Mouse is the perfect solution for users on the move or those who prefer a clutter-free workspace. Designed to fit comfortably in any size hand it provides perfect support for extended periods of use, whilst the integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The high definition optical sensor provides enhanced precision and accuracy, and extended battery life of up to 6 months.The low power indicator light will provide you with an early warning for when the batteries need changing. The mouse also comes with a micro USB receiver which is small enough to leave permanently plugged into your computer or using the built-in Stow-N-GoTM technology the USB receiver can be easily stored away into the mouse itself. *Battery life based on average usage per day and computing conditions.
  • Compatibility
    Designed to work with PC, Mac or Netbook computers.
  • Technology
    High-Definition sensor provides up to 8 months of battery life.
  • Optical Sensor technology
    1000 DPI high-precision laser sensor technology accurately responds to mouse movements.
  • Easy storage
    Stow-N-Go USB receiver is small enough to store inside the mouse while traveling.
  • Ergonomic
    Ergonomically designed to lend hours of comfort in any size hand.
Targus Wireless Optical Laptop - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
5.7 cm x 10.5 cm x 4 cm
65 g
European Union
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel, battery indicator
Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
Mouse
Wireless Receiver
Orientation
5.7 cm
10.5 cm
4 cm
65 g
European Union
Input Device
Wireless
2.4 GHz
Optical
Movement Resolution
1000 dpi
1 x USB - 5 pin Micro-USB Type B
Run Time (Up To)
6 months
