Targus Wireless Optical Mouse - Black
Quicklinx: BPYBWS00 Mfr#: AMW060EU
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
£12.32 ex VAT
£14.78 inc VAT
Targus Wireless Optical Mouse’s 1600 DPI sensor and compact design make it the ideal device for the office or on the go. Offering wireless freedom and built-in USB receiver storage for ultimate mobility. Comfortable to use with either hand and a scroll wheel for easy navigation, you can move through documents and webpages quickly. Enjoy a clutter free workspace at your desk or on your coffee table with this 2.4GHz wireless mouse.
  • Compatibility
    Designed to work with PC, Mac or Netbook computers.
  • Technology
    High-Definition sensor provides up to 8 months of battery life.
  • Optical Sensor technology
    1000 DPI high-precision laser sensor technology accurately responds to mouse movements.
  • Easy storage
    Stow-N-Go USB receiver is small enough to store inside the mouse while traveling.
  • Ergonomic
    Ergonomically designed to lend hours of comfort in any size hand.
Targus - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
5.9 cm x 9.5 cm x 4 cm
40 g
Europe
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1600 dpi
Scrolling wheel
AAA type
Apple MacOS X 10.4 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Mouse
Wireless Receiver
5.9 cm
9.5 cm
4 cm
40 g
Europe
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
3
Movement Resolution
1600 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
2 AAA batteries
AAA type
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Targus
Price Range Ex VAT: 0 - 50
